3.4 thermostat
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hotdog7, Nov 2, 2023.
  1. Nov 2, 2023 at 4:23 PM
    Hotdog7
    Hotdog7 [OP] Well-Known Member
    Fred
    1gen Tacoma
    Toytec 2.5-3" lift 2010 rims wheel spacers tundra brake upgrade
    I guess this is going to be a poll. What position does the thermostat go the little pinhead at 12:00 or 6:00 I watch bunch videos I see both one guy said it's to let air leave so 12:00 makes sense
  2. Nov 2, 2023 at 4:26 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    On a 3.4 the jiggle valve goes down. On a 2RZ or 3RZ, it goes up.
    Area51Runner likes this.
  3. Nov 2, 2023 at 5:10 PM
    Hotdog7
    Fred
    1gen Tacoma
    What does it do? I have no idea just thought it made sense to go up
  4. Nov 2, 2023 at 7:49 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    3.4 v6 jiggle valve is at 6 o’clock. I believe it typically goes at 12 o’clock on most cars but everything I’ve ever read about the 3.4 v6 is that it goes at 6 o’clock. This must be the exception. Idk why. Others on here know more why about than me.
  5. Nov 2, 2023 at 9:47 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Actually, it will work at either position.
    However, when it is set to the 6 o'clock position, your coolant temps will run about 10°F lower than what is stamped on the T-stats housing.
  6. Nov 3, 2023 at 6:55 AM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    After my heads were replaced I noticed my operating temp was higher than it had been. It was in the mid or upper 190's. I decided to check the thermostat position and sure enough they had the jiggle valve at 12 o'clock. I repositioned it to 6 and operating temp returned to what I was used to, 186f.
    I use an OEM thermostat which I believe are 180f. So the 6 o'clock position is closer than 12.
  7. Nov 3, 2023 at 10:26 AM
    Digiratus
    Roaming the PNW
    The RedHead
    FWIW, the OEM T-stat I had with the correct part number for my truck according to Toyota, had it's opening temp stamped (in C°) into its flange. IIRC it was 87.6° which converts to 190°F. When the jiggle valve was in the 12 o'clock position, the typical coolant running temps were 195-200°F. This is the same as when the truck was new.
    It is important to note that the higher running temps are ok and not too high when the rest of the system (radiator and fan and water pump) are all working within spec.
  8. Nov 3, 2023 at 1:09 PM
    Gen1andDone
    That's odd, pretty sure the OEM t'stat for my '02 3.4l (90916-03075) is described as being 180f and has 82c stamped on it. I can't remember exactly when I started using the ScanGuage 2 to monitor temps, but I'm almost certain it was before the first t'stat replacement and it has always averaged 186f.
  9. Nov 3, 2023 at 1:26 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Straight from toyota's horse's mouth....
    Jiggle....
    2.4 & 2.7 = Up (+ or - 15)
    3.4 = Down (+ or - 15)
    leid likes this.
  10. Nov 3, 2023 at 6:32 PM
    Hotdog7
    Fred
    1gen Tacoma
    I installed today 6:00 looks like this is how old one was in also.thanks for replays
