3.4 throttle body w/etcs issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by ope23, Mar 1, 2010.
  1. Mar 1, 2010 at 4:03 AM
    ope23
    ope23 [OP] Active Member
    andy
    Jasper,GA
    03 SR5 4X4
    window tint all the way around even the front windshield
    Ok so took the throttle body off for a 70k carbon build up clean...
    Took it apart and then back together exactly like it was now I have no pedal til' the very bottom, strange shifts, CEL illuminated, and difficult idle... I took the throttle position sensor off and then back on and it was perfect for like 4 miles and back to no throttle again... I've had to borrow a vehicle due to my daily commute. Does anyone have any tear down pictures, adjustments, schematics, or ideas???
    Thanks
  2. Mar 1, 2010 at 5:02 AM
    98tacoma27
    Ben
    Not Beech Creek
    What code is showing? Do you have the vac lines correct?
  3. Mar 1, 2010 at 5:05 AM
    98tacoma27
    Ben
    Not Beech Creek
  4. Mar 1, 2010 at 5:39 AM
    default83
    default83 Active Member
    Katy
    01 DC 2wd
    what did the gasket look like between throttle body and manifold?
  5. Mar 1, 2010 at 7:19 AM
    DD03SR5
    DD03SR5 Well-Known Member
    Derek
    Ontario,Canada
    03 SR5 4X4
    Deckplate,5100's,eibach's,Wheelers AAL,
    I had that same problem but it just happend randomly. With my truck it was the main. Computer not sending the signal to the throttle body. I would check the wires and make sure one did not get pulled out of the plug
  6. Mar 1, 2010 at 10:32 AM
    ope23
    andy
    Jasper,GA
    03 SR5 4X4
    I have no way of reading the code just yet.. I need to get it to the tech school and hook it up to the modus.. Thanks for those manuals, I found them last night.. It definitely feels like a mechanical issue with a linkage but they all seem correct.. all vacuum hoses are correct and the throttle body gasket looks great.. I will check all the plugs tonight and also test the circuits as well... Thanks guys for the ideas...
  7. Mar 1, 2010 at 2:23 PM
    mdmech02
    mdmech02 New Member
    Maryland
    04 Double Cab TRD
    I had the same problem aroun d 70000 miles. I think it was an internal position sensor.(it was a few years ago). Took it to dealership to read code. I hade to change out the whole throttle body. They said it couldnt be repaired. Hopefully this is not your problem because it was $1200 part.
