3.4 Timing
Discussion in '1st Gen. Tacomas (1995-2004)' started by ashleyroachclip, May 23, 2016.
  1. May 23, 2016 at 5:46 PM
    ashleyroachclip
    ashleyroachclip [OP] Well-Known Member
    I generally put this in the tech section, it does not get much traffic, and I would like an answer sooner than later.
    95.5 tacoma (duh) 3.4 4x4 manual trans.
    I have a lack of timing advance in the 3k-4.5 rpm range.
    It is not advancing timing at steady state driving ex, @60 and accelerate , timing drops to 2- 2.5 maybe 10*
    Let off the throttle and timing will jump to 30* , and I use this as an example.
    I figure cam ,crank position sensors, as well as tps and maf, should be components that communicate to the ecu timing.
    I have no codes, just the sotp, and live data to verify.
    I don't want to throw parts , to maybe fix the problem.
    I want to know how and why I have the problem, and how to verify and fix.
    Thanks
    Ashley
