3.4 transmission overheating
Discussion in '1st Gen. Tacomas (1995-2004)' started by Goldie 04, Jan 7, 2025.
  1. Jan 7, 2025 at 7:50 PM
    Goldie 04
    Goldie 04 [OP] Well-Known Member
    Azael
    West phx
    Goldie trd 2004 x4
    Lifted runner
    So my trucks tranny is overheating and throwing the torque converter code. But the converter has been replaced. Overhaul kit and solenoids replaced i mean the gears go in good and no slipping but i notice that it over heats when at highway speeds and specifically when letting off the gas. Would a bad tranny cooler cause this? Im getting ready to replace that and its filter i added but if anyone can help me out id appreciate it. The temps go up to 300 and throw the engine light and transmission oil light aswell.
  2. Jan 7, 2025 at 10:32 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Are you absolutely certain the torque converter is locking up? If it isn't, the trans will overheat. From cold, how much driving does it take to get it to overheat?
  3. Jan 8, 2025 at 12:40 PM
    Goldie 04
    Azael
    West phx
    Goldie trd 2004 x4
    Lifted runner
    How can i make sure? And ab 20 min when its running highway speeds it bumps up to 240 iv spent 2500 trying to fix the issue and still nothing makes a difference
  4. Jan 8, 2025 at 1:52 PM
    Goldie 04
    Azael
    West phx
    Goldie trd 2004 x4
    Lifted runner
    What things can cause a p0741 code? The mechanic is saying hes going to check the solenoids again but all 3 where changed
  5. Jan 8, 2025 at 2:35 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Converter lockup occurs after you get into overdrive (4th gear). When the TC locks up it is like a 5th gear. On mine the engine revs drop another 500 RPMs when the TC locks up.
    Google says this code indicates the TC is not locking up. Could be a bad solenoid or it's wiring.
    FWIW, 300°F is very bad for the trans fluid. Avoid getting it that hot and make sure the trans fluid gets changed out once that solenoid gets fixed. Even 240° for a sustained period will cause the fluid to start to degrade.
  6. Jan 8, 2025 at 2:38 PM
    Digiratus
    Roaming the PNW
    The RedHead
  7. Jan 8, 2025 at 2:55 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I would think you would see a noticeable drop in your RPM's. When I'm on the interstate doing 70mph my rpms drop to about 2250, and stay there. What are your RPM's doing when your cruising down the interstate when the Transmission Temps start to rise.
  8. Jan 8, 2025 at 3:06 PM
    Darce
    Darce Well-Known Member
    2003 Tacoma
    Did this start after you added the remote filter? Just a thought but is the filter head plumbed backwards as in outlet of trans to outlet of filter head?
  9. Jan 8, 2025 at 3:14 PM
    Goldie 04
    Azael
    West phx
    Goldie trd 2004 x4
    Lifted runner
    Mmm well i havnt really noticed anything with my rpm but maybe i should keep an eye for that. Everything seems good other then it overheats. The shop that rebuilt that tranny is going to check the solenoid again but i mean he said it was a new one and was working. And about the filter im not sure i follow with what your suggesting.
  10. Jan 8, 2025 at 3:15 PM
    Goldie 04
    Azael
    West phx
    Goldie trd 2004 x4
    Lifted runner
    N yea i do pull over when its gets to 300 and now its been running 200-230 way too hot for me its never ran that hot always 150-170.
  11. Jan 8, 2025 at 3:23 PM
    Darce
    2003 Tacoma
    It sounded to me like you added an external remote oil filter with the cooler, is that correct?
  12. Jan 8, 2025 at 3:32 PM
    Digiratus
    Roaming the PNW
    The RedHead
    What was the original reason for taking it to the shop. Was it overheating then? Was it throwing that same P0741 code?
  13. Jan 8, 2025 at 3:46 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    what he means, if you have an external Transmission filter, do you have the lines connected backwards.
