3.4 Trd Supercharger kit
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Jon64l, Mar 5, 2020.
Thread Status:
Not open for further replies.
  1. Mar 5, 2020 at 4:08 PM
    Jon64l
    Jon64l [OP] Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    Recently Rebuilt by previous owner at High Speed Lab approx 15,000 miles on it.
    What's included:
    Trd black supercharger
    Dynamic tensioner / hardware
    2 belts
    New and used bypass valves
    Snout support bracket
    Viton snout rebuild kit
    Timing cover w/smog sticker
    Dipstick relocation bracket
    Paperwork from rebuild
    What's missing:
    Check valve, very cheap and easy to replace, I've included the part number so you can reorder.
    What else you might need:
    Colder range spark plugs
    Vacuum hose or T fittings
    Wide band
    Aem Fic or 7th injector
    I purchased this from someone on this forum 20200304_182608.jpg 20200304_182620.jpg 20200304_182629.jpg 20200304_182643.jpg 20200304_182707.jpg 20200304_182758.jpg 20200305_124713.jpg 20200305_124722.jpg
    20191101_162331.jpg who said they couldn't afford the fuel mods. I used a Fic6 on my truck with this SC with great results. Without fuel and timing mods the truck ran lean and would ping. I pulled timing and added fuel in part throttle map and picked up so much torque and no ping. I highly recommend the Fic6.
    The previous owner put a new Trd snout on (noted in paperwork) but it leaked out the front seal a little (a known problem on some of them for some reason). I just periodically topped off the oil, it never ran low. I have a new Viton snout rebuild kit from RollingPerformance.com included.
    I am now running a turbo and no longer need the SC.
    $2200 plus shipping and PayPal fee.
    Located in Phoenix Az.
    mechanicjon likes this.
  2. Mar 5, 2020 at 7:26 PM
    brian.gonz
    brian.gonz Well-Known Member
    Brian
    Manor, Texas
    Supercharged 2012 TRD Sport DC
    TRD Supercharger, Relentless Fab Stingray, TRD Pro Wheels, BFG, AMP Research Runners.
    Where are you located
  3. Mar 5, 2020 at 7:48 PM
    Jon64l
    Jon
    Phoenix
  4. Mar 6, 2020 at 7:28 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    lol flipping sc's is just your thing eh :p
  5. Mar 6, 2020 at 7:43 AM
    Jon64l
    Jon
    Haha maybe so. The last one I had to sell because work was slow. This one I dont have to sell, but no point in letting it just sit. @Dalandser
    Dalandser likes this.
  6. Mar 6, 2020 at 7:54 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Just got an aem, might have to ask you a couple setup questions.
    Jon64l[QUOTED][OP] likes this.
  7. Mar 6, 2020 at 1:43 PM
    04TrDtAcO4x4
    04TrDtAcO4x4 Well-Known Member
    2003 Tacoma
    So tempting!!!
  8. Mar 6, 2020 at 2:12 PM
    Jon64l
    Jon
    SOLD!
  9. Mar 6, 2020 at 2:29 PM
    04TrDtAcO4x4
    2003 Tacoma
    Dang!!!!! I'm always too late
    Jon64l[OP] likes this.
  10. Jun 16, 2020 at 7:35 PM
    BrianTaco75
    BrianTaco75 Well-Known Member
    Brian
    1995 Taco / 2019 Taco
    yeah me too
  11. Jun 16, 2020 at 8:32 PM
    spinyard
    spinyard Well-Known Member
    the question is, why do these superchargers always come off? People getting rid of the truck? I think people install them and aren't quite happy with the $ to HP gains.........
  12. Jun 16, 2020 at 8:41 PM
    Jon64l
    Jon
    You MUST fuel it! They are awesome when properly fueled. The part throttle torque is impressive, don't even need to go Wot most of the time. Yes they are kinda spendy, and require the fuel kit, but a turbo needs that too and it doesn't bolt on in a couple hours.
    My truck is just turbo now, but I'm wanting to go back to twin charged sooo bad. Az summer is brutal, so I'm waiting until the heat dies down to play that game again.
  13. Jun 16, 2020 at 9:23 PM
    BrianTaco75
    Brian
    what exactly about fuel do you mean? Bigger fuel pump/Tune or what?
  14. Jun 16, 2020 at 9:25 PM
    Jon64l
    Jon
    Pump, injectors, ecu/tune. Its all on the tune.
  15. Jun 17, 2020 at 11:14 AM
    spinyard
    it the urd 7th injector still the way to go? Is there a "boxed" solution to fueling? i.e. so and so injectors, tune, etc? Methanol injection only?
  16. Jun 17, 2020 at 11:33 AM
    Jon64l
    Jon
    7th is good for a boxed solution.
    Another route is..
    190lph fuel pump
    Is300 320cc injectors
    Aem Fic
    Meth is another story. It is awesome for Wot pulls, but, not so good for part throttle (where most of the driving is done) You need a nice progressive kit Imo.
    The problem is, the ignition timing table is calculated from knock sensor readings above 3000rpm. The knock sensors are off when below 3k. So, if you do a lead foot pull to redline with meth (which is awesome for guarding against detention) the computer sees no knock and advances the timing. The computer is always trying to advance timing, until is sees knock then dials it back a hair. So after you do the fun pulls with meth and go back to "normal" driving, the computer has advanced timing in the area below 3000rpm thinking that there will be no knock. You basically lied to the computer. It basically thinks you are running 118 octane fuel and it can advance all the timing it wants.
    Now I know people get away with meth kits, maybe they are ignorant, maybe they live in cold weather climate, maybe other stuff. For me, when I put the blower on, I noticed ping right away at part throttle boost. I pulled timing with the Fic and it has been gone since. I've run 12psi twin charged on a stock block with no knock, 91 octane.
  17. Jun 21, 2020 at 8:25 PM
    22re4runner4x4
    22re4runner4x4 New Member
    toyota manual 4x4
    got her installed, thanks again
  18. Jul 10, 2020 at 8:45 PM
    Rldanie
    Rldanie Punisher78
    Colorado
    2002 Supercharged, 2” pulley, FIC, Methanol, Transgo Shift Kit
    Engine Performance upgrades: Supercharged (Magnuson) FIC/6 Champion Radiator Toyota Corolla thermostat 168° JBA Headers JBA cat back exhaust Upgraded fuel pump Volant Cold Air Intake With custom plexiglass cover TransGo Transmission A340F Valve Body upgrade B&M Transmission cooler Methanol Injection 2 inch pulley Future Plans Supra Injectors Light weight crankshaft pulley Leather seats Off-road upgrades 3” rough country lift 33x12.5” Dick Cepeks Other upgrades: JL Audio 12W6 Sub in custom box JL Audio C5 Mids and tweets all the way around Sound dampened whole cab Transmission temp sensor Gen Tex rear view mirror (temp and compass) Blue instrument panel, a/c control panel lights, shifter, ashtray, glove box. Blacked out badges Blackout bumpers and grill MariMoto Projectors with demon eyes LED Taillights Second generation leather steering wheel with audio controls Custom leather wrapped automatic transmission shifter 3rd gen 4 Runner key ring light (blue) 3rd gen 4 Runner hood scoop
    FIC mounting options?
    I wanted to do this
    Credit to @mechanicjon
    BUT
    I have some sort of a four-wheel-drive cruise control box in the way
    Wow the idea above is awesome , I’m not sure it’s going to work for me and I’m looking for other ingenuity.
    Thanks!
  19. Jul 11, 2020 at 7:47 AM
    Jon64l
    Jon
    You could try moving that factory computer, or try to mount up high behind glove box maybe? It could also go above steering column. Just don't put it in the engine bay.
    Rldanie likes this.
  20. Jul 11, 2020 at 5:36 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    There is room in the driver side kick panel, that's where I moved my aftermarket alarm control to.
Thread Status:
