3.4 twin charged
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jbogstaco, Mar 15, 2021.
  1. Mar 20, 2021 at 12:04 PM
    #101
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    My Fic6 works perfectly.
    It has a brand new wire harness.
    TacoBike likes this.
  2. Mar 20, 2021 at 12:18 PM
    #102
    Jbogstaco
    Jbogstaco [OP] Well-Known Member
    Jeremy
    Supercharged 2002 Tacoma double cab trd
    3 inch lift, supercharged
    What’s your # man definitely interested in buying it , what are you looking to get ?
  3. Mar 20, 2021 at 12:26 PM
    #103
    Jon64l
    Jon
  4. Mar 30, 2021 at 12:14 AM
    #104
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Sorry @TacoBike been away from the forum for a while.
    Yeah can't think of much to add. I looked into it a lot because of the insane lego-ability of it with this particular platform, and the electronics challenge to make the S/C bypass at the right times. Others have mentioned (and I got to see for myself once I made my S/C bypass) that the S/C bypass can't bypass all of the air as RPMs climb, its diameter was just made big enough for low load bypassing.
    I agree with people saying its pointless- but as someone else mentioned in this thread, the engineering challenge is what entices some. We have so many things in our lives we don't need, but we do it anyhow. Flagship phone but do things a 4a can do with ease? Yep. 3500 sq foot house for empty nesters... yep. etc etc. In all my automotive hobbyist days I did not see an opportunity like this come a long so easily- TRD bolt-on S/C in the OEM intake manifold location. CXRacing turbo kit at an insanely affordable price for what it is. Great piggybacks that left MAF based enrichment far behind.
    @Jon64l, my God that manifold is art. And so tasteful to recirc the wastegate.
    Jon64l likes this.
  5. Mar 30, 2021 at 12:16 AM
    #105
    Jbogstaco
    Jeremy
    So my main issue would be getting the turbo boost to not be blown off from the super charger ?
  6. Mar 30, 2021 at 6:22 AM
    #106
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Waiting for the part out like
    Jon64l likes this.
  7. Mar 31, 2021 at 10:19 PM
    #107
    TacoBike
    TacoBike The Researcher
    Mason
    Shingle Springs, California
    2000 3.4 Ext Cab TRD 4x4 with original SC
    ARP head studs Supercharger FIC6 AFR gauge painted fenders audio install
    Definitely a very fun project that may get more attention someday, perhaps one day I shall. But for now I finished my researching I was trying to do. I still believe it has its place, but is less applicable to the regular person.
  8. Apr 4, 2021 at 9:53 PM
    #108
    Jbogstaco
    Jeremy
    Okay guys ordering more shit tomorrow, as for injectors is 325cc good I was ordering direct fits of lce performance with the urd fuel pump. Got the aem fic 6 from @Jon64l and until I decide if I wanna run a turbo I was gonna order a 2.1 pulley for some more boost. Probably gonna pay for a dyno since I’m not too good with tunes and my buddy is unfamiliar with the software on aem
    https://www.lceperformance.com/Performance-5VZ-Modified-Fuel-Injector-Set-p/1062213.htm
    https://urdusa.com/deatschwerks-dw100-tank-fuel-pump-5vz-3rz-2rz/
  9. Apr 4, 2021 at 10:02 PM
    #109
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    At that point you'd been money ahead (by alot!) if you'd dropped in an LS motor. More power, reliability and overall better drivability.
    Rldanie and Speedytech7[QUOTED] like this.
  10. Apr 4, 2021 at 10:08 PM
    #110
    Jbogstaco
    Jeremy
    @Jon64l if I was ever swapping I’d be looking for a 1.5 Jz. Gotta stay with Toyota man
  11. Apr 4, 2021 at 10:38 PM
    #111
    Jon64l
    Jon
    The 325cc will be enough for a stock SC setup, maybe a 2.2 pulley. Wont be enough for twin charged, probably not enough for 2.1.
    My stock injectors were maxed out at around 4200rpm with a stock SC. Kept adding duty cycle with no change in afr. I've been using 440cc injectors since then.
    Jbogstaco[OP] likes this.
  12. Apr 5, 2021 at 4:30 AM
    #112
    Jbogstaco
    Jeremy
    As far as that urd fuel pump goes it that a good buy or is that not gonna deliver enough fuel either ?
  13. Apr 5, 2021 at 8:03 AM
    #113
    Jon64l
    Jon
    It is a Walbro pump as far as I remember. They do work, but I upgraded to a Aem. Only buy from a authorized dealer, there are countless counterfeit fuel pumps of all brands out there.
    Speedytech7 likes this.
  14. Apr 5, 2021 at 8:42 AM
    #114
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Personally I'd avoid Walbro pumps, the Aeromotive 340 works well and isn't loud
  15. Apr 5, 2021 at 8:44 AM
    #115
    Jbogstaco
    Jeremy
    Thanks guys I’m gonna order the parts after work today . So question I know I put in my tuner before the injectors and pump . Do I need to input anything into it or can I just drive it to a shop with all the new stuff in and they can tune it ?
  16. Apr 5, 2021 at 11:37 AM
    #116
    Jon64l
    Jon
    1. Determine if you have Narrow or Wide band factory O2 sensors.
    2. Download Ecu pinout for your vehicle year or order Boomslang harness.
    3. Always disconnect batter before doing any electrical related work.
    4. Carefully plan out and install Aem wire harness. Only use soldier connections, no butt connectors.
    5. Test your wiring by using the Aem patch harness. Truck should run like stock.
    6. Install Aem software from their website onto your computer.
    7. Flash the Fic with latest firmware version. Follow the instructions exactly. You will need a paperclip to push the micro switch when prompted. You technically should already be good since I did this before sending it to you.
    8. Disconnect Fic.
    9. Open Aem software. Open File. Open basecal. Save New. New name 12345 or whatever. Close.
    10. Open 12345. Connect USB cable to Fic. Click Connect icon. Window will say file doesn't match. Send to or copy from Fic? You want to copy. This will import that last info on the Fic I left and get you started quicker.
    11. Click Guage Icon. It should now actively display your local ambient air pressure on the Load Guage. Go ahead and gently blow on the boost port on the Fic and watch the Guage change. This is the internal Map sensor working. My local pressure is 14.2, anything over this is considered boost. Yours may be different.
    12. Save as.
    13. Of your wiring tested good and you have again Disconnected the battery, you can now plug in the Fic. You will need to safely run a vac/pressure line from the intake manifold to the Fic. Make sure this line is connected behind the throttle plate to reference vacuum and pressure.
    14. Connect battery.
    15. Open Software. Click Calibrated Tps. Follow instructions.
    16. Start vehicle.
    17. Calibrate Rpm. Follow instructions.
    18. Open fuel map. Open Ignition map. Open Guages. The cursor will now follow the rpm and load cells that you are currently in. Hint: Don't pull any timing near your Idle cells, truck won't start.
    19. You will need to reconfigure the O2 setup. Mine was Narrow Band so its set for that. If you are wideband it will be different.
    20. Lots of good fic videos on YouTube
  17. Apr 5, 2021 at 11:40 AM
    #117
    Jbogstaco
    Jeremy
    @Jon64l sweet man heading to post office in 10 will send u shipping tracker , when can you send out my harness ?
  18. Apr 5, 2021 at 12:20 PM
    #118
    Jon64l
    Jon
  19. Apr 5, 2021 at 2:31 PM
    #119
    Jon64l
    Jon
    21. Don't forget to wire in a aftermarket wide band sensor, like the Aem Uego or Innovate. Most should have a analog wire you hook up to the Fic. You then input the voltage/afr values from its instruction book into the appropriate table in the Fic. Now you can view and log Afr at all load and rpm points. This is very helpful for closed and open loop tuning.
  20. Apr 5, 2021 at 7:45 PM
    #120
    Jbogstaco
    Jeremy
