3.4L, 5VZE-FE cylinder Heads
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Red03Taco, Dec 28, 2019.
  1. Dec 28, 2019 at 8:06 AM
    Red03Taco
    Red03Taco [OP] Well-Known Member
    Davie, Florida
    2003 Radiant Red, Tacoma, 2WD, Prerunner, TRD, Double-Cab
    Stock
    The heads are no longer available, cleaned up garage and they had to go.
    I have a set of 3.4L 5VZ-FE cylinder heads for sale, asking $150.00 for both of them. I can ship just keep in mind that they weigh 26 lbs each and would have to be at least a medium size box.
    I will work with you to ship and will not charge extra, what ever it cost will be what you pay.
    Thanks,
  2. Dec 31, 2019 at 8:32 AM
    Mustang2xvt
    Mustang2xvt Member
    2002 tacoma
    More info on the heads, please... Why were they pulled off, do they need work?
  3. Dec 31, 2019 at 11:33 AM
    Red03Taco
    Davie, Florida
    Stock
    The bottom end of the motor failed, rod was shot through the block and I replaced the engine with a JDM replacement engine. I tore the motor down and the piston did not make contact with the head when I pulled it off. I figured I would offer it for sale to somebody that may be able to use instead of throwing them away.
    everything was working fine, I was totally surprised by the engine failure. I believe that the heads are in good shape. You can see from the pictures that no contact was made.
    One last note; the heads are exactly the way they were removed from the motor, I did not clean anything up.
  4. Dec 31, 2019 at 12:06 PM
    Mustang2xvt
    Mustang2xvt Member
    2002 tacoma
    Appreciate the quick response... I believe one of the heads on my 02 has cracked. The truck was smoking like a train the other day. Hope to remove the heads off the truck this weekend to verify and will contact you if that is the case.
  5. Dec 31, 2019 at 1:28 PM
    Red03Taco
    Davie, Florida
    Stock
    Ok, I’ll work with you on the shipping, just let me know.
