3.4L Back fires and I need help
Discussion in '1st Gen. Tacomas (1995-2004)' started by AK1stGen, Oct 11, 2017.
  1. Oct 11, 2017 at 10:12 PM
    AK1stGen
    AK1stGen [OP] Active Member
    Austin
    01 Tacoma
    3" lift Snorkel Rear e-locker Front ARB locker Front ARB bumper Rear wrap around bumper Bed rack Winch Dual batteries
    I need some 3.4l experts advice/wisdom
    My 01 Taco 4x4 3.4 manual runs like sh*t. It idles fine, but backfires, misses and Boggs down above 2,000 rpms only underload(revs all the way up to 5k in nutreural fine)
    It backfires from the intake not the exhaust which points to the engine running lean
    So here's what I've done so far:
    -Checked for vacuum leaks (there are none that I can find)
    -replace fuel filter
    -replace intake gaskets
    -replace spark plugs/wires
    -replace all ignition coils
    - replace maf sensor, throttle position sensor, o2 sensor(upstream)
    -replaced fuel pump
    -replaced all fuel injectors
    - checked valve timing (all timmimg components were replaced 2,000 miles ago along with water pump and thermostat.
    -cleaned throttle body
    All of these items have done nothing! And I am completely stumped.
    --Also a side note, I recently replaced the engine with one out of a 99 4 runner, but it has ran really good up until last weekend.
  2. Oct 11, 2017 at 10:38 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  3. Oct 12, 2017 at 12:50 AM
    AK1stGen
    Austin
    01 Tacoma
    Yes, fuel pressure is good
    Dalandser likes this.
  4. Oct 12, 2017 at 2:04 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Plugged cat maybe? Try lessening the exhaust pipe from manifold. enough to allow about 1/4 inch gap. Then test drive.
  5. Oct 12, 2017 at 2:05 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    When did this start running bad? was it gradual or all of a sudden?
  6. Oct 12, 2017 at 5:35 AM
    tony2018
    tony2018 Well-Known Member
    I've heard that using the wrong spark plug could have issues.
  7. Oct 12, 2017 at 9:56 AM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    +1 for correct plug usage. 5VZ-FE requires dual grounded plugs.
  8. Oct 12, 2017 at 10:59 AM
    AK1stGen
    Austin
    01 Tacoma
    I'm using dual grounded denso plugs
    Both cats are completely gutted because they were clogged about 15,000 miles ago and I didn't have time or money to replace them at the time.
    The problem started last weekend and got worse as I drove it.
  9. Oct 12, 2017 at 10:59 AM
    tony2018
    Ouch, your secondary o2 must be reading some fucked up shit.
  10. Oct 12, 2017 at 11:02 AM
    AK1stGen
    Austin
    01 Tacoma
    I just get a cat inefficiency code, but it has never affected the proformance of the engine.
  11. Oct 12, 2017 at 11:03 AM
    tony2018
    I would make sure you have no exhaust leaks.
  12. Oct 12, 2017 at 11:04 AM
    AK1stGen
    Austin
    01 Tacoma
    I have one small exhaust leak in the muffler
  13. Oct 12, 2017 at 11:11 AM
    Bulldogs129
    Bulldogs129 Don't find fault, find a remedy
    Malcolm
    Mississippi
    2018 TRD, OR, 4wd, Dblcab, 3.5l, & 2002 Tacoma 4wd, SR5, TRD, 3.4L, auto
    @Speedytech7
    Any help?
  14. Oct 12, 2017 at 11:14 AM
    Bulldogs129
    Malcolm
    Mississippi
    @AK1stGen
    How’s the head gaskets? There’s a few ways to test...
  15. Oct 12, 2017 at 11:27 AM
    AK1stGen
    Austin
    01 Tacoma
    I've done a compression check and there's no oil in the coolant and no coolant in the oil. So that rules out head gasket. Compression was between 170 and 175.
  16. Oct 12, 2017 at 11:27 AM
    Glamisman
    Glamisman Well-Known Member
    after all of the parts replaced the only thing I can think of off the top of my head is the fuel pressure regulator... pull the vacuum line and see if there is gas coming out of it or in the line.
  17. Oct 12, 2017 at 11:32 AM
    AK1stGen
    Austin
    01 Tacoma
    I'll check the regulaator, so when I pull the vacume line off gas should be coming out the return line? Is this with the engine off? I'm little confused with what you meant by that
  18. Oct 12, 2017 at 11:33 AM
    Bulldogs129
    Malcolm
    Mississippi
  19. Oct 12, 2017 at 11:34 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    How is your catalytic converter? If you hold it up to the sun can you see through it?
    Bulldogs129 likes this.
  20. Oct 12, 2017 at 11:39 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    He said they're gutted I believe?
