3.4L Back fires and I need help
Discussion in '1st Gen. Tacomas (1995-2004)' started by AK1stGen, Oct 11, 2017.
  1. Oct 12, 2017 at 11:41 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Yup
  2. Oct 12, 2017 at 11:43 AM
    AK1stGen
    AK1stGen [OP] Active Member
    Austin
    01 Tacoma
    3" lift Snorkel Rear e-locker Front ARB locker Front ARB bumper Rear wrap around bumper Bed rack Winch Dual batteries
    Gas is fine, I drained the rest out when I did the fuel pump and put in fresh gas
  3. Oct 12, 2017 at 11:43 AM
    AK1stGen
    Austin
    01 Tacoma
    Yes cats are gutted
  4. Oct 12, 2017 at 11:47 AM
    Rons01TRD
    Rons01TRD Well-Known Member
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    Throttle Position sensor maybe???:notsure:
  5. Oct 12, 2017 at 11:47 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Sounds like timing is off tooth or two then
    randd likes this.
  6. Oct 12, 2017 at 11:47 AM
    AK1stGen
    Austin
    01 Tacoma
    - Replaced
  7. Oct 12, 2017 at 11:49 AM
    AK1stGen
    Austin
    01 Tacoma
    Checked timing yesterday
  8. Oct 12, 2017 at 11:51 AM
    Rons01TRD
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    If I am not mistaken there are a couple of different types of TPS Sensors, I believe the 2001's are different than the 2003/04 3.4's...just putting this out there to help....
  9. Oct 12, 2017 at 11:51 AM
    Speedytech7
    You check belt tension too?
  10. Oct 12, 2017 at 11:52 AM
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Do you have a scangauge or anything that can read fuel trims?
  11. Oct 12, 2017 at 11:52 AM
    Rons01TRD
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    How about your MAF sensor????
  12. Oct 12, 2017 at 11:53 AM
    Brice
    Brice Turbo Member
    Brice
    Texas
    Did you even read the first page???
  13. Oct 12, 2017 at 11:58 AM
    AK1stGen
    Austin
    01 Tacoma
    I am aware of that
    Belt tension was good, tensioner was replaced with timing belt 2000 miles ago
    I don't, I can possible barrow one, what would I be looking for in fuel trims. I'm not smart when it comes to the computer diagnostics
  14. Oct 12, 2017 at 12:01 PM
    Brice
    Brice Turbo Member
    Brice
    Texas
    It would help determine how hard the ECU is working to keep the truck at a 14.7:1 AFR. For instacne if the values were like +(-)20 you would know that you are way rich or way lean (negative trims being rich and positive ones being lean)
  15. Oct 12, 2017 at 12:03 PM
    #35
    AK1stGen
    Austin
    01 Tacoma
    Okay I'll see what I can do about barrowing a scan tool
    Brice[QUOTED] likes this.
  16. Oct 12, 2017 at 12:07 PM
    #36
    Bulldogs129
    Bulldogs129 Don't find fault, find a remedy
    Malcolm
    Mississippi
    2018 TRD, OR, 4wd, Dblcab, 3.5l, & 2002 Tacoma 4wd, SR5, TRD, 3.4L, auto
    All the symptoms sound like a failing MAF....I know you replaced it, but dog-gone it sure sounds like the problem. Do you have a warranty on the new MAF?
  17. Oct 12, 2017 at 12:16 PM
    #37
    Brice
    Brice Turbo Member
    Brice
    Texas
    I thought this as well.
    Bulldogs129[QUOTED] likes this.
  18. Oct 12, 2017 at 12:19 PM
    #38
    AK1stGen
    Austin
    01 Tacoma
    I'll try replacing it again
  19. Oct 12, 2017 at 12:28 PM
    #39
    Bulldogs129
    Malcolm
    Mississippi
  20. Oct 12, 2017 at 2:39 PM
    #40
    Glamisman
    Glamisman Well-Known Member
    No, there should be no fuel at the vacuum line. If there is it means the rubber diaphram is broken. Engine on ONLY to check for the presence of vacuum at the line.
