3.4L Back fires and I need help
Discussion in '1st Gen. Tacomas (1995-2004)' started by AK1stGen, Oct 11, 2017.
  1. Oct 13, 2017 at 9:17 PM
    #81
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    12.5 would be on the lean side. Have you checked fuel pressure woth a gauge?
  2. Oct 13, 2017 at 11:15 PM
    #82
    AK1stGen
    AK1stGen [OP] Active Member
    Austin
    01 Tacoma
    3" lift Snorkel Rear e-locker Front ARB locker Front ARB bumper Rear wrap around bumper Bed rack Winch Dual batteries
    Yes, 35psi
    LT FTRM1 is not at -.8 at idle and ST FTRM1 is 0.8
  3. Oct 13, 2017 at 11:16 PM
    #83
    AK1stGen
    Austin
    01 Tacoma
    Also ignition advance is 18.5 degrees, that seems high to me but I don't know what it should be at idle.
  4. Oct 14, 2017 at 9:25 AM
    #84
    mechanicjon
    Jon
    Scottsdale Arizona
    I believe 35psi is low. Don't have access to a FSM right now. 38 to 44psi is spec. i think.
    Brice likes this.
  5. Oct 14, 2017 at 11:15 AM
    #85
    AK1stGen
    Austin
    01 Tacoma
    It's with in spec, 32-38 is what it's supposed
  6. Oct 14, 2017 at 12:56 PM
    #86
    AK1stGen
    Austin
    01 Tacoma
    32-38psi is spec
    I was wondering if anyone know what the throttle position is suppose to read at idle and WOT, with my scanner hooked up in reading 11% at idle and only 76% at WOT. I know I replaced the throttle position sensor but this seems off
  7. Oct 14, 2017 at 1:21 PM
    #87
    AK1stGen
    Austin
    01 Tacoma
    Nevermind on that, this is within spec.
  8. Oct 14, 2017 at 9:31 PM
    #88
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    I believe this spec is actually correct. I have to find the sheet that says so though...
  9. Oct 14, 2017 at 11:22 PM
    #89
    mechanicjon
    Jon
    Scottsdale Arizona
  10. Oct 14, 2017 at 11:25 PM
    #90
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    From: FSM says 38-44 psi with ignition on, 33-38 psi at idle, and 38-44 psi with the vacuum sensing hose to the regulator disconnected.
  11. Oct 14, 2017 at 11:30 PM
    #91
    mechanicjon
    Jon
    Scottsdale Arizona
    Our 3.4v6 doesn't have vacuum to the fuel pressure regulator.
  12. Oct 14, 2017 at 11:31 PM
    #92
    mechanicjon
    Jon
    Scottsdale Arizona
  13. Oct 14, 2017 at 11:45 PM
    #93
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    My $Free.50 version only had torque specs. Other forum says:
    "I believe factory specs are 38-42psi as measured on the fuel rail at the front of the motor. "
  14. Oct 14, 2017 at 11:49 PM
    #94
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Isn't there a line that goes from the intake to it? Noob on that stuff though.
  15. Oct 15, 2017 at 12:08 AM
    #95
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Darn late to the party haha. I only have AllData Pro access at my local college - I usually just park in their parking lot and get what I need to get.
  16. Oct 15, 2017 at 12:16 AM
    #96
    mechanicjon
    Jon
    Scottsdale Arizona
    The line runs to the intake tube before throttle body. No vacuum to it.
    Dalandser[QUOTED] likes this.
  17. Oct 15, 2017 at 12:17 AM
    #97
    mechanicjon
    Jon
    Scottsdale Arizona
    You don't have the FSM?
  18. Oct 15, 2017 at 12:23 AM
    #98
    BartMaster1234
    Tyler
    Flux Capacitor
    oh duh I totally forgot about that. you still need it? I can look it up
  19. Oct 15, 2017 at 12:23 AM
    #99
    mechanicjon
    Jon
    Scottsdale Arizona
    Nah D got it.
  20. Oct 17, 2017 at 10:02 AM
    #100
    Bulldogs129
    Bulldogs129 Don't find fault, find a remedy
    Malcolm
    Mississippi
    2018 TRD, OR, 4wd, Dblcab, 3.5l, & 2002 Tacoma 4wd, SR5, TRD, 3.4L, auto
    @AK1stGen what's the latest...any progress or updates? are you :burnrubber:yet?
