3.4L engine chug/clunk at idle while in gear and warmed with video!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scoobz121, Nov 11, 2019.
  1. Nov 11, 2019 at 9:57 AM
    Scoobz121
    Scoobz121 [OP] Member
    Hi all-
    I recently acquired a 2002 tacoma with 190k miles. The engine makes a chugging sound when the engine is warm and only in gear (not park or neutral). The sound climbs with RPM but is not noticeable really above 2k or while driving and most noticeable at low RPM. The sound more pronounced when the AC clutch is engaged; however, the sound is still made when the AC is turned off.
    The truck does not burn oil and drives fine otherwise. The sound seems to be more pronounced in the cabin on the drivers side. Timing belt and water pump was recently change along with throttle body cleaning.
    I am going to try and disconnect the AC belt first. Does anyone know if this is possible without removing the power steering belt?
  2. Nov 11, 2019 at 2:56 PM
    rogerman
    rogerman Well-Known Member
    Roger
    HNL 808, SPN 670
    2000 Tacoma SR5 V6 4wd 5speed
    I'm sure someone will chime in but post a video of the sound so the TW vets can help you.
  3. Nov 11, 2019 at 5:38 PM
    Scoobz121
    Good idea, I'll have it up shortly
  4. Nov 25, 2019 at 10:42 PM
    Scoobz121
    Bump videos attached.
  5. Feb 23, 2023 at 5:32 PM
    thescientist
    thescientist Member
    2001 Tacoma Xtra Cab - 3.4L 4x4
    OP, did you ever find the cause of the chugging? I’m having the same problem.
