3.4l engine swap... flash ecm?!?
Discussion in 'Technical Chat' started by BigBad181, Aug 31, 2017.
  1. Aug 31, 2017 at 3:11 AM
    BigBad181
    BigBad181 [OP] New Member
    Zack
    SC
    04' taco doublecab prerunner
    4/3" lift, body mods, cb radio, full exhaust... Its my baby baja rig :) love my Yota! !!
    Swapped out my 5vzfe for another... got it in but no fire and the same check engine light is on that was on with the previous engine... I'm guessing flash the ecm? All advice welcome and thanks guys!
  2. Sep 3, 2017 at 1:01 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Did you install your harness and sensors with the engine you installed?
    Just why did you replace the engine??
    If the battery was disconnected during the swap all the codes will be cleared .
    The question is just what code??
    What is this flashing of the ECM ??
  3. Sep 5, 2017 at 11:32 AM
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    You cannot flash the ECM in a first gen.
  4. Sep 6, 2017 at 12:44 PM
    BigBad181
    Zack
    SC
    Ill have to get back to you with the codes, i used harness that WA on the truck, had to change the top of the intake to get my MAF and throttle body to comply . Engine behaves as if 180 out of time pops tgem pops back on itself the code was a misfire on cylinder 3 .I'll be back with more info
