3.4l missfire on cylinder 3
Discussion in '1st Gen. Tacomas (1995-2004)' started by outdoorsman1218, Mar 2, 2014.
  1. Mar 2, 2014 at 5:53 PM
    outdoorsman1218
    outdoorsman1218 [OP] New Member
    1997 toyota t-100 sr5 3.4l
    2in body lift, 4in suspension lift
    blew head gasket, did both heads. put back together. miss on cylinder 3. replaced plugs and wires. moved coils around. still miss on cylinder 3
  2. Mar 2, 2014 at 6:52 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Could be a fuel injector issue for that cylinder causing the misfire.
  3. Mar 2, 2014 at 7:33 PM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    My thoughts exactly ^
  4. Mar 2, 2014 at 7:51 PM
    68dave
    Dave
    Since you had the engine apart recently check to make sure that the #3 injector wiring connector is plugged in all the way, could be as simple as that.
  5. Mar 2, 2014 at 7:53 PM
    jammdogg
    jammdogg Well-Known Member
    James
    Hillsboro, OR
    13 Spruce Mica DCLB
    6" ProComp lift on 35 MT's. ARB Bumper.
    Buddy just had same issue. What they said ^^^^. Was the injectors.
  6. Mar 2, 2014 at 10:16 PM
    outdoorsman1218
    pulled intake off this evening, to check for anything. all hoses, plugs. are good. moved injectors around, see if it follows. pulled each coil out one at a time and inserted spark plug. all three firing
  7. Mar 3, 2014 at 5:08 AM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    Compression test, just to cover the basics.
  8. Mar 4, 2014 at 8:35 AM
    outdoorsman1218
    think i got it. valve shims. low compression in # 3. did compression test before tearing apart, so i knew better. hooked air compressor to cylinder. blowing threw intake. valves were staying open. or not closing all the way. what a pain. anyone had this trouble.
  9. Mar 4, 2014 at 8:49 AM
    fast5speed
    Washington D.C.
    So basically...you're way overdue for a valve adjustment?
  10. Mar 4, 2014 at 2:29 PM
    egebhardt
    egebhardt Well-Known Member
    Eric
    Rapid City, SD
    '99 4x4 Xcab 5spd V6
    None
  11. Mar 4, 2014 at 2:39 PM
    fast5speed
    Washington D.C.
    So you're valves are not closing completely....which means the shims are too big/thick. That doesn't make sense....your shims wouldn't have gotten thicker . They can only wear down and cause the valves to open less, NOT in excess.
    Your valves my be not closing completely, but I fail to see how the shims are responsible (solely going in the fact that shims cannot get thicker, only thinner). You should look for other components that have failed/worn.
  12. Mar 4, 2014 at 2:41 PM
    fast5speed
    Washington D.C.
    Also, if shims are responsible, I would think that they would have to be so far out of spec (SO thick)not only is there zero clearance, but that even when there is zero lift from the cam, they are being pushed open some.
  13. Mar 4, 2014 at 2:50 PM
    BamaToy1997
    Bill
    Navarre, FL
    I would be willing to bet that during the head gasket job the OP accidentally lost track of the shims/cups and installed one from another location. I suggest doing a full clearance check on all of the valves. Spec I believe is on a sticker on the hood.
  14. Mar 5, 2014 at 7:24 AM
    outdoorsman1218
    clearance is .006 to .009. what a hassle. got them all to work at .006 except for three of them. will be hear today. hooked my compressor up to my compression checker. blew air back threw motor. was running right through my intake, with vavles closed. was not an easy job
