3.4L Oil Leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaEli, Nov 11, 2019.
  1. Nov 11, 2019 at 9:14 AM
    TacomaEli
    TacomaEli [OP] Well-Known Member
    Eli
    Roanoke, Virginia
    2000 Tacoma XtraCab SR5 TRD 3.4L Auto
    My 2000 3.4L has an oil leak. I cannot tell exactly where it's coming from. It collects in the skid plate and it drips off of the bell housing and around the transmission fluid pan. I'm not sure if it's dripping down and running off from somewhere higher. Any advice is appreciated.
  2. Nov 11, 2019 at 9:15 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Rear main seal
  3. Nov 11, 2019 at 9:32 AM
    02hilux
    Planet: EARTH
    Common is valve cover and half moon. Possible rear main.
    Have you look?
    vasinvictor likes this.
  4. Nov 11, 2019 at 1:39 PM
    TacomaEli
    Eli
    Roanoke, Virginia
    I’ve looked. I just cant tell if its the back of the valve covers dripping down onto the transmission or of it’s the RMS itself
  5. Nov 13, 2019 at 5:37 AM
    Tacomaman63
    Tacomaman63 Well-Known Member
    Stan
    2004 tacoma TRD 4x4
    step bars grille guard
    I just had that problem I thought the bolts were loose on the valve covers but it was the oil sending unit, check that
  6. Nov 13, 2019 at 9:13 AM
    TacomaEli
    Eli
    Roanoke, Virginia
    Is that near the oil filter?
  7. Nov 13, 2019 at 11:19 AM
    Tacomaman63
    Stan
    2004 tacoma TRD 4x4
    I actually don’t know where it is but if you look it up on YouTube I’ll bet they’ll show you
  8. Nov 13, 2019 at 2:40 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Have you tried lightly tightening the cam cover (valve cover) bolts? See if they are loose? Sometimes - you can get a bit more life out of the seals only because they rattled loose. I also had an oil sending unit leak but that's towards the front drivers side. Super easy fix for that one.
    GQ7227 and cruiserguy like this.
  9. Nov 13, 2019 at 3:01 PM
    exminnesotaboy
    exminnesotaboy Well-Known Member
    Maple Grove, MN
    01 Tacoma 4x4 V6 SR5 TRD Xtra Cab
    Bilstein 5100's / OME 881's / Wheelers 5 leaf pack / Level8 MK6/ 265/75-16 Bridgestone Dueler tires
    I have a similar leak leak and thought it was the rear main seal. After looking at it, I’m about 95% sure its associated with the valve covers/half moons just dripping down. Already ordered all the parts from camelback and will tackle it this winter.
    cruiserguy likes this.
  10. Nov 13, 2019 at 5:48 PM
    TacomaEli
    Eli
    Roanoke, Virginia
    No sure, I think I’m going to do the valve covers after I get the timing belt done. I know a retired Toyota mechanic that will do the valve cover gaskets for $50.
    GQ7227 likes this.
  11. Nov 14, 2019 at 2:48 AM
    exminnesotaboy
    Maple Grove, MN
    That will do your VC gaskets, but there are a few things that could be recommended when he is in there. Not necessary, but while I am doing mine, I will also be replacing the TB gasket, plenum gaskets, half moons, etc.... at 150k on my truck, I thought it would be good measure. But if he is a Toyota mechanic, he should know what needs to be done and $50 is a super deal if it gets your issue corrected
    GQ7227 likes this.
  12. Nov 14, 2019 at 5:18 AM
    TacomaEli
    Eli
    Roanoke, Virginia
    Yessir, I was also thinking about doing the rear cam plugs
  13. Nov 14, 2019 at 6:49 AM
    vettehigh
    vettehigh Tacoma Tank
    Jon
    Upstate, NY
    What does that entail (labor wise)?
    GQ7227 likes this.
  14. Nov 14, 2019 at 6:51 AM
    02hilux
    Planet: EARTH
    A whole lot of work. Transmission or engine must come out to access the RMS
  15. Nov 14, 2019 at 6:53 AM
    vettehigh
    Jon
    Upstate, NY
    :eek:
    GQ7227 likes this.
  16. Nov 14, 2019 at 7:16 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i would give him twice that amount!
  17. Nov 14, 2019 at 7:18 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    is that a known problem on the 3.4 after a certain age or mileage?
  18. Nov 14, 2019 at 8:05 AM
    02hilux
    Planet: EARTH
    Varies
    GQ7227[QUOTED] likes this.
  19. Nov 14, 2019 at 8:33 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    is there preventative maintenance that can be done to avoid that RMS?
  20. Nov 14, 2019 at 8:50 AM
    02hilux
    Planet: EARTH
    Nope.
    GQ7227[QUOTED] and vettehigh like this.
