3.4l prerunner engine surges at medium throttle
Discussion in '1st Gen. Tacomas (1995-2004)' started by mackattack07, Dec 12, 2010.
  1. Dec 12, 2010 at 8:16 PM
    mackattack07
    mackattack07 [OP] Well-Known Member
    william
    Jacksonville NC/Graceville FL
    99 Prerunner 3.4/2000 4Runner3.4/85 Pickup22R
    my 99 prerunner surges at mid throttle. easing along its smooth and easy and wide open throttle it shits and gets but mid throttle it surges you can feel it and hear it. It still shifts smooth even tho its surging. any help btw its completely bone stock with 339,000 miles and still runs strong.
  2. Dec 12, 2010 at 8:18 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Start by cleaning the MAF sensor-bet it can use it:) and congratulations to your tough truck for giving all that service!!
  3. Dec 12, 2010 at 8:49 PM
    mackattack07
    william
    absolutely no codes have popped up its just aggravating ill have to look up how to clean it
  4. Dec 12, 2010 at 10:09 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    They have MAF cleaner at the auto stores-very rapid drying which is what you need. I assume your airbox is the same as my 2001? Can you tell us or do a pic of the airbox and sensor location should be right behind it. If it is the same I will tell you how to do it. I do mine every 5000 miles. If I can I'll try to do a vid if you need one let me know.
  5. Dec 13, 2010 at 7:39 AM
    mackattack07
    william
    mine is right after the airbox the same as my wifes 2000 4 runner. i work on helos so ill probly uses cpc type II its cleaner fast drying and all of that.
