3.4L Rebuilt Long Block
Discussion in '1st Gen. Tacomas (1995-2004)' started by YoDaddy1, Jul 10, 2014.
  1. Aug 1, 2014 at 11:36 AM
    BamaToy1997
    Bill
    Navarre, FL
    Perhaps you have seen something on these heads that I haven't? So far I have yet to find a 5VZ head cracked. Plenty of blown head gaskets, but never a cracked head. I do agree with rebuilding what you have. Buying a long block is no different than taking your OLD engine to a shop and have them rebuild it for you. Many shops will do this, and the price is fair.
  2. Aug 2, 2014 at 7:58 PM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Just paid 8K for a reman motor. Labor provided by a local shop. Engine came from Jasper out of TX. Includes 3 yr warranty, and the shop matched that for the labor. Reason for engine swap was a cracked head (drivers side #4 cylinder) most likely due to repeated helicoil inserts for that spark plug. Truck ran fine once fuel air mix was correct, mis-fire on cold startup. Needed to smog truck and couldn't pass visual wth check engine light.
    Price was a bit steep, but it's a new warranted motor. 3500 for heads alone and only a 30 day warranty. Daughters truck, so reliability is paramount.
  3. Aug 3, 2014 at 10:23 PM
    BamaToy1997
    Bill
    Navarre, FL
    The shop matched it for warranty? Strange since Jasper warranties their engines typically parts AND labor anyway. lol. Ah well. At least you know if the engine fails, you are well covered!
  4. Oct 20, 2015 at 8:54 PM
    JakeInGrayTacoma
    JakeInGrayTacoma Active Member
    Jake
    SoCal Mtns
    95 4x4 gray tacoma
    Get back up to snuff cuz it wasn't maintained. I got xm radio in it.
    I'm still debating whether a used or reman engine for mine (I am still driving it) and am looking at various vendors to get an engine from...
    Haven't bought one yet, really don't know where to get one.
  5. Oct 20, 2015 at 8:57 PM
    JakeInGrayTacoma
    Jake
    SoCal Mtns
    95 4x4 gray tacoma
    Where did you buy your reman engine? I still haven't decided where to buy one from.
  6. Oct 27, 2015 at 7:01 AM
    2scars
    2scars Swollen Member
    Brandon
    RVA
    2003 TRD 4x4 Doublecab
    All-pro, T-G, Budbuilt, Warn, Tepui, Homefab rear bumper
  7. Apr 26, 2018 at 9:05 PM
    BobF
    BobF New Member
    Bob
    02’ silver Tacoma TRD
    I know this is an old thread, just curious if your still happy with your “engine world” motor, I’m shopping for one and they are half the price, but only a 6 month warranty.
  8. Apr 27, 2018 at 8:06 AM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    I've used engine world for my Acura when I had it. No issues at all with the motor. They even delivered it to shop for no charge. Nest 650.00 for a motor. Coworkers have used them too with no issues.
  9. May 12, 2021 at 1:30 PM
    chirkin
    chirkin Well-Known Member
    james
    yosemite ca
    1996 tacoma xcab 4x4
    ome 5100 up front ad leaf in rear 31 inch tires
    @YoDaddy1 how long did the rebuild from engine world last you?
  10. May 12, 2021 at 5:35 PM
    1997tacomav6
    Denver
    The lower end on these engines are unbelievable strong,
    It’s the top end that has problems and usually from an over heated situation at one time because it has aluminum heads that don’t handle heat well
    My motor popped a head gasket at 480,000,
    The bottom end was still in great condition.
    Zero oil burning
    I would fix the top end because your still on the lower end mileage for a 3.4 and you know the condition of the bottom end now,
    Unless you find an engine in a wrecked truck 100k miles or less that you can do a carfax and hear running for under 1500.00
  11. Sep 7, 2021 at 3:47 PM
    chirkin
    james
    yosemite ca
    how did this motor turn out for you were you happy I currently have 150 miles 3 days of driving on one of there 3.4 motors curious to know how yours treated you? thanks
