3.4l Supercharger is Back!!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by LC Engineering, Oct 1, 2015.
  1. Oct 3, 2015 at 10:57 AM
    #41
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    I'm at 5000 ft.
  2. Oct 3, 2015 at 11:03 AM
    #42
    AZoverlandTaco
    AZoverlandTaco How do I change my profile name?
    Eric
    Flagstaff
    Toyota 4 Life
    Under certain engine loads the stock fuel system isn't able to provide enough fuel for efficient combustion. This leads to a lean misfire or ping. If the URD 7th injector kit comes with a smaller s/c pulley it would increase the boost.
  3. Oct 3, 2015 at 11:08 AM
    #43
    Yota64
    Yota64 Professional Threadjacker
    Can't wait til the 4.0 comes back but man will I miss that TRD badge.
    Lord Helmet likes this.
  4. Oct 3, 2015 at 11:09 AM
    #44
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    This is important I think. If you were at sea level, the stock fuel system probably would create potential damage to your engine from running lean all of the time. At least this is what I've read.
  5. Oct 3, 2015 at 5:04 PM
    #45
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Im pretty sure the s/c is meant to be run on the stock fuel system. Granted it's not optimized, I don't think there is anything catastrophic that could occur. As for the 7th, the claim is the added fuel through the s/c creates a better seal between lobes and recovers lost boost. Sounds reasonable to me.
    huj2000 likes this.
  6. Oct 12, 2015 at 5:36 PM
    #46
    Yota64
    Is it the exact same s/c as before or will it be stronger since there's not a Toyota warranty on it?
  7. Oct 14, 2015 at 11:20 AM
    #47
    Wulf
    Wulf no brain just damage
    rock raisin
    I would bet it's identical except for the lack of the TRD logo. There's probably not a whole lot they can change without engineering a new design.
  8. Oct 18, 2015 at 9:12 PM
    #48
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Ooooh I hope LCE will still be selling these by the time I will be able to afford one!
  9. Oct 18, 2015 at 9:23 PM
    #49
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    The 7th injector adds more fuel during boost to eliminate the dreaded ping.
  10. Jan 16, 2016 at 3:04 PM
    #50
    Kapncam
    Kapncam Well-Known Member
    Adam
    West Virginia
    SC 2015 Black Tacoma
    Super Charged, TRD exhaust
    If it was $2000 or less I'd buy it but I just can't justify $3000.
  11. Jan 16, 2016 at 4:16 PM
    #51
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    So when is the 3RZ version coming out?
  12. Jan 16, 2016 at 4:21 PM
    #52
    vlodpg
    vlodpg Well-Known Member
    Connecticut
    15 Tacoma TRD Off Road 6sp Supercharged
    TRD Supercharger/URD Stage II Clutch
    "Speed costs money son, how fast do you want to go?"
    Well?
  13. Jan 16, 2016 at 4:27 PM
    #53
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    I agree. $3k for 65-70hp gain.......not worth it. 120-150hp gain or $1000-$1250 cheaper? Yeah I would by one instantly.
  14. Jan 16, 2016 at 5:05 PM
    #54
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    LCE has had a couple 3RZ superchargers listed for a long time. Low and high boost versions.
    devinzz1 likes this.
