3.4L timing belt
Discussion in '1st Gen. Tacomas (1995-2004)' started by wildjerseyfirefighter, Oct 21, 2010.
  1. Nov 2, 2010 at 4:59 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Maybe if you pull the radiator. There isn't much room in there. You can either use a really long breaker bar and bump the starter with the bar jammed into something, or make the tool which took me about 30 minutes.
  2. Nov 3, 2010 at 5:53 AM
    fireman_343
    fireman_343 Ultimate TRD
    Brian
    Columbus, OHIO
    05 TRD Dlb Cab
    Viper Alarm, XD Series Wheels, Pioneer touch screen radio/nav system.
    Good link! I need to do mine soon! Going out today to get the parts!
  3. Feb 21, 2011 at 9:54 PM
    pilotj
    pilotj Well-Known Member
    Jay
    Grand Mesa, CO
    2001 Tacoma SR5 TRD 3.4L 226,000 like new!
    Deck plate w/baffle, grey wire mod, defroster switch mod, LED footlights, LED cap lights, magnetic theft deterent...
    I finally changed mine at 175,000 miles. Looked like new! Compressed the tensioner with a large "C" clamp. Just be carefull....
  4. Feb 22, 2011 at 12:39 PM
    ywen
    ywen Well-Known Member
    if the water pump leaks, where would the coolant leak most likely accumulate?
  5. Feb 22, 2011 at 12:41 PM
    ywen
    someone indicated to me that there is a bolt/nut that is torqued down extremely tight.. that in order for him to break it loose, it had to crank the engine with a breaker bar attached to it to knock it loose when the bar hit the frame..
    forgot what part this was for.. does it ring a bell?
  6. Feb 22, 2011 at 1:01 PM
    jwicker
    jwicker Well-Known Member
    Southern Indiana
    2003 Lunar Mist Double Cab 4x4
    ARB shell
    Crank pulley bolt is set at a massive torque spec.
    There is a sticky for making the tool.
  7. Feb 22, 2011 at 2:35 PM
    MaTt98
    MaTt98 Well-Known Member
    Medford Or.
    96 4Runner SR5 V6
    Runner SR5, xeon headlights, 6inch kc spotlights, cb in ashtray mod, roof rack, 2.5 inch lift in front with dodge 1500 coils in the rear and skyjacker shocks
    i changed mine at 175k and the water pump was leaking like crazy the dryed antifreeze clumps fell off and landed on my belt making it jump two teeth! luckly nothing got dammadged
