3.4L V6 guru? cam plug help
Discussion in '1st Gen. Tacomas (1995-2004)' started by derekp, Jan 2, 2010.
  1. Jan 2, 2010 at 3:35 PM
    derekp
    derekp [OP] giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    Is there a V6 guru around? I think the cam plug (top of the motor, back side near the firewall?) on the passenger side is leaking a bit. Nothing horrible at this time, but makes me a bit concerned. Anyone else face similar issues?
    Derek P
    Germantown, MD
  2. Jan 2, 2010 at 4:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Can you post pics of the leak?
  3. Jan 2, 2010 at 4:19 PM
    derekp
    Derek
    Grand Forks, ND
    I can barely see the leak. I used a dental style mirror ( ) to see it. I am just guessing that is what it is. I thought it was some sort of plate at first but the more I looked the more I figured it was a cam plug.
  4. Jan 2, 2010 at 4:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    There is a Semi Circular plug (s) in the back....They are between the Valve cover, and the head....Is that whats leaking? They look like a half circle.
  5. Jan 2, 2010 at 4:29 PM
    derekp
    Derek
    Grand Forks, ND
    Correct...but I *think* it was a full circle. I could very well be wrong on that though. It looked like a mounting plate bolted over it or right next to it. It was difficult to see via a small mirror and flashlight though.
  6. Jan 2, 2010 at 4:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats all I can think it would be......You can remove the valve cover, and pull the semi Circle plug out, clean the old gasket off, install new gasket, and re install.
  7. Jan 2, 2010 at 4:55 PM
    derekp
    Derek
    Grand Forks, ND
    Thanks, *sounds* pretty straight forward. Probably need to replace the valve cover gasket as well, correct? I still need to find some folks to help with the timing belt/water pump replacement. I am around 122k miles.
    Derek P
    Germantown, MD
  8. Jan 2, 2010 at 5:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, The Valve cover gasket will need to be changed too. Maybe find some folks on TW that live near ya for some help.
  9. Jan 2, 2010 at 5:46 PM
    derekp
    Derek
    Grand Forks, ND
    Thanks, Chris!
  10. Jan 2, 2010 at 5:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Glad to help :)
