3.4l vs. 4.0l
Discussion in '1st Gen. Tacomas (1995-2004)' started by adamrick2002, Apr 20, 2011.
  1. Apr 20, 2011 at 7:19 PM
    adamrick2002
    adamrick2002 [OP] New Member
    hello im new to this forum and a new tacoma owner. its a 98 4x4 trd ext. cab with a 5 spd. currently a 3.4l. bought it for 600 bucks because it needs head gaskets so i figured itd be a good cheap project. question is i found a good low mileage 4.0l out of a 07 tacoma for a good price that runs good with only 57,000 miles on it and was wondering how hard it would be to put that in instead versus putting head gaskets in. will it bolt up and just be a computer swap or should i just fix the motor in it? thanks
  2. Apr 20, 2011 at 7:22 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Yep....save yourself the trouble and fix the 3.4.
  3. Apr 20, 2011 at 7:28 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I saw a first gen with a 4.0 swapped into it recently. It was a full long travel built up truck though. Lots of custom fabrication on the truck, so custom motor mounts was no big deal to them I guess. Definitely didn't look like a bolt in operation. On the plus side, you're in Texas so you might not have to smog it?
  4. Apr 20, 2011 at 11:18 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    They also probably spent a ton of money, or have a fab shop and do this kind of stuff often.
  5. Apr 21, 2011 at 12:06 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    no motor swap for Tacos is a simple swap. Id stick to the 3.4 as well. You would have to do TONS of work to make it fit right....granted it would be cool...i am tempted to put my 7mgte in mine haha
  6. Apr 21, 2011 at 4:42 AM
    JeffsJeep04
    JeffsJeep04 Well-Known Member
    Jeff
    Menomonie, WI
    2010 DCSB SR5 V6
    Dang, that rear axle is worth what you paid for that truck alone, nice score!
  7. Apr 21, 2011 at 5:51 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    3.4 is a solid engine. Rebuild it, then if you want more power you can supercharge it. swapping in a 4.0 would be wayyyy too much work for what you'd get out of it.
