3.4L with a weird misfire issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by ABTSyncro, Mar 25, 2013.
  1. May 23, 2018 at 9:42 PM
    Horsefried
    Horsefried New Member
    Scott
    2002 Club Cab SR5 TRD
    bone stock
    OK, had a 303 problem on a 02 with 300+K; new NGK wires (and coil packs as they were pushing 17 years old), problem solved!
  2. Nov 29, 2018 at 2:31 PM
    Dickey
    Dickey Member
    1997 Toyota Tacoma 3.4L 4x4
    Replace engine
    Same problem on 97 it's vacuum leaky in valves. Need to have both heads rebuilt.
  3. Nov 30, 2018 at 7:44 PM
    Glamisman
    Glamisman Well-Known Member
    you are wasting your time proceeding until you verify the compression.
    rant on/
    since the adoption of the OBDII standards, techs have seem to have lost the ability to diagnose... the computer says P030X, it MUST be right... they load the parts cannon and pull the trigger... all of this when a compression test and a vacuum gauge could have figured out if the motor was mechanically sound first.
    rant/off
    do a compression test on all of the cylinders with the throttle wide open. look for all cylinders within 10% of each other. I see you have swapped coils/plug wires etc with no change so we can eliminate that, for now. Next look at fuel trims when it is warm. anything greater that +5% indicates a vacuum leak. This could mean an actual vacuum leak like a gasket up to an intake valve not sealing 100% due to valves being too tight. There are too many variables to look at to say this or that is THE problem. Start with the basics. If you don't have the tools, time or experience this is just going to be a frustrating expensive exercise.
    fatback803 and little squirt like this.
  4. Dec 2, 2018 at 2:09 PM
    Dickey
    Dickey Member
    Replace engine
    Valve problem. Leaking vaccum past valves. Need heads worked
  5. Jun 3, 2020 at 2:46 PM
    Exclusivewhtboy
    Exclusivewhtboy New Member
    Mychael
    1995 T 100
    Exhaust
    I've got the random multiple misfire problem my ECM is bad may not be your problem but it was mine
