3.5 inch lift????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jusmac, Jun 7, 2010.
  1. Jun 7, 2010 at 8:02 AM
    jusmac
    jusmac [OP] Well-Known Member
    I have searched this out already a couldnt find anything. i was wondering if anyone out there has a coilover kit that is set at 3.5. i am running the Revtek 3" spacer and want to switch over to the toytec coilover kit. with the revetek i am getting tire rub so i want to set them at 3.5 and was wondering if anyone had any issues or anything. pic would be nice also, thanks in advance.
  2. Jun 7, 2010 at 8:10 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    at 3.5" you will be putting a lot of stress of parts that dont need it, upper ball joints, steering joints, CV joints if your 4x4.
    3" is the max you should go with a coil lift. after that you gotta do a drop bracket or spindle lift
  3. Jun 7, 2010 at 8:33 AM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    +1000;)
    Look into a basic DB lift and save yourself a lot of headaches!
  4. Jun 7, 2010 at 11:13 AM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Yea if you want over 3" need drop down setup. Check out RCD, great lift for about 4-5", and easy on your cv angles
