3.5" lift paired w/ 1/2" diff drop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoRD16, Jan 9, 2018.
  1. Jan 9, 2018 at 7:05 AM
    TacoRD16
    TacoRD16 [OP] Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    I have Fox 2.5 C/O w/ resi set at 2.75" lift in the front with a 1" spacer front diff drop (1/2" drop). I've always noticed my CV's were pretty flat with the diff drop and a lot people don't run diff drops with 3" lifts. Obviously we are talking about 4x4 vehicles only. I'm curious if anyone has put a 1/2" spacer on top of the C/O to to achieve a 3.5" lift taking advantage of the 1/2" diff drop. I know people say don't combined lifts and that shocks geometry are taken into account when valving to specific vehicles but is it not plausible? If anything it would make it a bit stiffer early in the travel and softer later in the travel due to geometry of the LCA lever arm. I want thoughts!
    arnette64 and ChadsPride like this.
  2. Jan 9, 2018 at 7:10 AM
    ChadsPride
    Sponsored by TacomaWorld.com
  3. Jan 9, 2018 at 7:27 AM
    Murkules
    Murkules Well-Known Member
    Dane
    Hawaii
    2016 Tacoma TRD Offroad DCSB Super White
    :bananadead:
    ChadsPride likes this.
  4. Jan 9, 2018 at 7:36 AM
    AlabamaBlackSnake
    AlabamaBlackSnake Well-Known Member
    Jim
    4wd TRD OR 2017 dcsb
    Chrome..lot of chrome
    Don’t do diff drops
    ChadsPride and fatfurious2 like this.
  5. Jan 9, 2018 at 7:38 AM
    TacoIII
    TacoIII Mr. Boombastic
    Andrew
    Albuqerque
    10 Taco 4x4 off road package
    3" OME 886 coils, ARB bumper warn M8000, Lightforce 240's and 255/85 16 KM2, Redline hood struts,arb twin air compressor, 4.88's, Tepui kukenam, Pelfreybilt bed rack and rear high clearance with swing out, and custom offroad bodywork
    Why? I have one. Other than a few horror stories of cracking the diff housing, I feel it does good for longevity.
  6. Jan 9, 2018 at 7:40 AM
    AlabamaBlackSnake
    Jim
    Dirty Harry and ChadsPride like this.
  7. Jan 9, 2018 at 7:41 AM
    TacoIII
    Andrew
    Albuqerque
  8. Jan 9, 2018 at 7:55 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    If you want 1/2" of lift, use 1/4" spacers. I dont think it will be to much of an issue. Maybe getting a different spring for your coil could help achieve more lift. What is your spring rate? 600lbs? on a 12" spring? maybe you can grab a 650lbs 13" spring. You will have let preload and get better lift.
  9. Jan 9, 2018 at 8:06 AM
    TacoRD16
    Houston, TX
    Yeah I read that post before I installed the diff drop. That skid was modified poorly allowing the diff mount to be below the skid. I have mobtown skids and they are designed (spaced) for 1" diff drops. I'm not saying if I came down hard enough where it could bend my 3/16" plate and keep going into the mount but the force would have to be significant and I'm not racing my trucks at 70+ mph smashing rocks like he was.
    TacoIII likes this.
  10. Jan 9, 2018 at 8:10 AM
    TacoRD16
    Houston, TX
    Correct currently running 600 lb springs and will be moving to 650 lbs. I would prefer not to go 13" possibly losing up travel with more coils or is it the same length cold just spaced with an extra in?
    I was thinking to achieve more lift without using up more down travel from the C/O so I'm not bottoming out the C/O.
  11. Jan 9, 2018 at 12:42 PM
    Brokinarrow
    Brokinarrow Well-Known Member
    Brian
    Garner, NC
    2017 Tacoma TRD Offroad
    Thangs and stuff
