3.5-liter Atkinson cycle V-6
Discussion in '3rd Gen. Tacomas (2016-2023)' started by trx680, Aug 11, 2015.
  1. Aug 11, 2015 at 4:30 AM
    trx680
    trx680 [OP] Member
    Someone explain the "Atkinson". What/Who is Atkinson?
  2. Aug 11, 2015 at 4:38 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  3. Aug 11, 2015 at 4:40 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    And James
    James Atkinson
    ItalynStylion likes this.
  4. Aug 11, 2015 at 6:45 AM
    jonnyozero3
    jonnyozero3 Well-Known Member
    Dry places
    '99 TRD OR V6 M/T
    OME, sliders, dents, hail damage, soiled armrest. Lightbulbs.
  5. Aug 11, 2015 at 7:11 AM
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
  6. Aug 11, 2015 at 9:20 AM
    d k
    d k Well-Known Member
    West Coast
    Very basic - it has a shorter compression cycle than the power cycle - which improves efficiency.
    The original Atkinson engine achieved this through bell cranks and levers. In the modern engine this is achieved by varying the intake valve event.
    Intake valve stays open as the piston is coming up, pushing some of the charge back up the intake port. Then the valve closes and you get ignition shortly after.
  7. Aug 11, 2015 at 9:26 AM
    TacoJonn
    TacoJonn Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    In the animations it looks like gas is being wasted out of the valves. Guess I am not understanding right.
  8. Aug 11, 2015 at 9:36 AM
    d k
    West Coast
    Its not wasted.
    Its stored.
    For the next cycle that charge is ready and only little more needed. Thats where the efficiency comes from.
    Remember, as long as the valve is open, much less energy is used moving the piston...
  9. Aug 11, 2015 at 9:38 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Sort of. Not exactly "wasted" just pushed back out to be used in the next stroke.
    The basic idea of the Atkinson cycle is to limit amount of gas and air being detonated so that the resulting cylinder pressure at dead bottom of the expansion stroke is equal to or as close to 1 atm as possible (Ie, use as much of the potential energy of the detonation as possible). In the Otto cycle, at dead bottom of the expansion stroke, the cylinder pressure is still much greater than 1 atm and still wants to "do work" but is wasted out when the exhaust valves open.
    Otto cycle will make better power as more gas is detonated per stroke but the Atkinson cycle will utilize each detonation more efficiently.
    Not really. The efficiency comes from using roughly the entire potential energy of the detonation in the down stroke.
    TacoJonn[QUOTED] and jonnyozero3 like this.
  10. Aug 11, 2015 at 9:49 AM
    d k
    West Coast
    You certainly explained it better.
    What Im curious about is how the Atkinson cycle reacts with boost?
    It will essentially take away from the entire principle of the A cycle.
    D
  11. Aug 11, 2015 at 9:52 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Good point, never really thought about that. I don't think Toyota's method would work too well with boost. Would def be harder to push that air back out against the pressure. Probably why Toyota did away with the S/C program? :notsure:
  12. Aug 11, 2015 at 10:43 AM
    d k
    West Coast
    Im thinking maybe a centrifugal might work.
    Less boost when down low and anyway, when the throttle plate is closed, it wouldnt go against boost necessarily.
    Once boost builds, switch to general Otto cycle?
    Could work? Maybe?
  13. Aug 11, 2015 at 12:49 PM
    tubesock
    tubesock Well-Known Member
    StAndrew likes this.
  14. Aug 11, 2015 at 12:57 PM
    Noahs2015Taco
    Noahs2015Taco aka TheOverlandingDad
    Michael
    Contra Costa County
    '15 TRD Off Road - Manual w. TRD Quick Shifter
    King 2.5 25001-119A EXT with Icon Billet UCA giving a 2.5" lift in the front, Icon 2.0 w. remote resi, OME HD Dakar Leaf pack giving a 3" lift in the back. Wheelers Superbumprs paired with All-Pro U-Bolt flip kit. 17" Black 4Runner TRD Pro Rims - 32" for DD 17" Black 4Runner TRD Pro - 33" BFG KM2 255/80r17 for dedicated off road set. Dissent Offroad Bed Rack over a softopper
    Ah the Miller Cycle. The most successful commercial application for this type of engine was the Mazda Millenia S. Never owned one but they seemed like pretty decent cars.
  15. Aug 11, 2015 at 12:58 PM
    SharkyPR
    SharkyPR Well-Known Member
    Central Florida
    2009 Civic Si
    All bolt ons + tuning solution. Capable of running high 13's.
    Guys the new Turbo 4 of Toyota/Lexus are Atkinson capable (cycle hybrids). So there is nothing wrong with adding boost to this engines.
    They are just playing safe.
  16. Aug 11, 2015 at 1:20 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    I think in the Future they may boost this engine and offer it in the Tundra as a EcoBoost challenger. Everyone knows Toyota needs to do something about the powertrain in the Tundra.
  17. Aug 11, 2015 at 1:32 PM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    The shuffling of reliable engines and technology is Typical of Toyota. The performance of the 4.0 is generally lauded and appreciated by the Taco crowd. They just want something more efficient. This seems to be the least expensive way toward that end. This may be the only place the motor appears until it us upgraded more for other vehicles. I din't see The Tacoma being a trendsetter for motors for very long. When we get all the specs, we may see it's mostly made from parts out of the bins of other vehicles an Tundra and Highlander are two good places to start.
  18. Aug 11, 2015 at 3:14 PM
    d k
    West Coast
    Who wouldve thought a full size F150 was gonna have a smaller engine than the Taco?
    Noahs2015Taco likes this.
  19. Aug 11, 2015 at 3:19 PM
    =JSG=
    =JSG= Well-Known Member
    Canada
    2006 OR to 2021 DC TRD OR 4x4 SB
    Morimoto 2 Stroke 3.0 lows, Squadron-R Sport , Method NVs, Bilstein 6112/5160
    That or they will be offering TRD turbo kits like the supercharger kits ;)
  20. Aug 11, 2015 at 5:19 PM
    d k
    West Coast
    That should be interesting...
    We know the Ecoboost 3.5 is esily capable of 650hp, so who knows??
