3.5 or 4 in lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ben 03 tacoma, Jan 24, 2014.
  1. Jan 24, 2014 at 4:45 AM
    Ben 03 tacoma
    Ben 03 tacoma [OP] New Member
    Cape Girardeau mo
    4WD SR5 TRD Offroad
    I am trying to find a true 3.5 or 4 in lift for around a thousand dollars. Fabtech has one but its for a pre runner. I would like to have a lift that I can use 33x11.50 tires on my truck. If anybody has any suggestions it would be much appreciated. Thanks
  2. Jan 24, 2014 at 5:28 AM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Your cv's will bind after 3".
    Stay at 2.5" and you won't have issues.
    Trim for tires if it rubs.
  3. Jan 24, 2014 at 5:37 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    If you want a 4" lift you will need a db lift.
  4. Jan 24, 2014 at 6:01 AM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    2.5 or 3" lift with a bit of trimming and beating down the pinch weld will allow for 33x11.5 tires. I suggest OME or Toytec for the "around a thousand dollars" mark.
  5. Jan 24, 2014 at 7:39 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No one makes a 33x11.5 tire...unless your referring to a 285/75..
    But yes, no real 4'' lift out there unless you get a drop bracket lift.
    You can fit the tires easy with just some light trimming and hammering on a 2.5-3'' lift
