3.5 rear end
Discussion in '1st Gen. Tacomas (1995-2004)' started by mudjunkie, Oct 15, 2008.
  1. Oct 15, 2008 at 9:48 PM
    mudjunkie
    mudjunkie [OP] Well-Known Member
    clearwater fl
    96 tacoma sx l
    header,short rack and pinion, heavy duty shocks, grill guard, flowmaster exhaust,pacesetter header without catalytic converter, one 10 inch xant sub with a mtx amp, off road lights,diamondplate tool box,rhinolined inside cab,ngk plugwires.
    RZN161L-TRMDKAB 3.583 what does this 3.583 mean i am sure it is my rear end gearing what exactly does it mean
  2. Oct 15, 2008 at 9:54 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    well, if im understanding correctly, then you want to know what 3.58 gearing means for you...
    basically the pinion gear(input) has to spin 3.58 times to spin the ring grear once, so the driveshaft will spin 3.58 times more than the tires do.
    A 3.58 is a 'tall' (numerically low) gearing so it will yield you good fuel economy from letting the engine run at a lower RPM while cruising the highway or freeway.
    hope this is what you were looking for.....
  3. Oct 15, 2008 at 10:02 PM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    thanks now my truck is 4 wheel drve and i would like to put biger tires on it 32 or 33 but will i have to regear it and is this gearing considered weak
  4. Oct 15, 2008 at 10:05 PM
    RelentlessFab
    Eric
    Sparks, NV
    actually, this is a strong gear set. the lower the gearing(numerically higher like 5.29) is actually weaker because the pinion gear gets smaller and the teeth are also smaller on the gearset since there are more of them on the ring and the pinion gear got smaller. i'd say that with the 4cyl and 32 or 33's a set of 4.10 gears would probably be a good match.
  5. Oct 15, 2008 at 11:40 PM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    thanks for the good info i get confused with this gearing stuff
  6. Oct 16, 2008 at 6:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Generally the gears arnt weaker until around 5.29's or more. Event though the pinion may be a little smaller, more teeth can engauge the ring gear at any given time, thus giveing an increase in the strenghth. The weak link is not always the size, but the teeth. For example, a Toyota 29 spline shaft is the same size as a Toyota 31 spline shaft, but the 31 spline shaft is stronger because there is more contact surface area, by haveing more teeth.
  7. Oct 16, 2008 at 6:59 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    I have never taken the time to research this to find out what all the "gearing" stuff means, but always wondered.
    Thanks for the info. It makes COMPLETE sense!
    As far as oversized tires go, your speedo gets all jacked up. Is having that recalibrated the same thing as "re-gearing"? Do you have to change your gearing ratio to correct the speedometer for the larger tires?
  8. Oct 16, 2008 at 10:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can change the gearing to correct the speedo, but, since the speedo is electric, many times using an speedo calibrator is just as effective.
  9. Oct 18, 2008 at 7:44 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    electric speedo on a 1st gen.... what you talkin bout willis
  10. Oct 18, 2008 at 10:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ooopsie....I thought it was an '06....:eek:
  11. Oct 19, 2008 at 7:51 AM
    350TacoZilla
    Hancock MD
    ha ha its ok I just had to catch you on it... but since molly is so cute I'll let it go this time
  12. Oct 19, 2008 at 8:03 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL, Thanks, Buddy. :D
    I think she is getting tired of bailing me out. :)
