3.5 rough country lift opinions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jer1623, Jul 25, 2022.
  1. Jul 29, 2022 at 7:01 AM
    Aqualoon
    Aqualoon More stickers!
    Minnesota
    2019 Off-Road DCSB Cavalry Blue
    Barrydd and SpeySquatch like this.
  2. Jul 29, 2022 at 7:07 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Lol depends on your son. When I was 18, I was off roading maximas and Camry’s lol. Young people don’t treat their cars the best.
  3. Jul 29, 2022 at 1:32 PM
    SpeySquatch
    2016 TRD OR DCSB
    depends on your needs and what you are doing. I personally don’t understand spending $40+k on a truck and putting a leveling kit, spacer, block whatever on the vehicle. For just a bit more you can get a nice suspension upgrade (Eibach 1.0 or 2.0 kit, Bilstein 5100, etc) and it won’t f**k up your components over time like spacers and blocks do (as long as you are realistic up to 2-2.5” max of lift height).
    Leaf packs are more expensive due to production and supply issues, but I’ve had Dakar (medium and heavy) and Icon RXT packs and I really like the Icon RXT. I’m not even a fan of Icon shocks (more reasons than one…), but the leaf pack is nice at slow or high speed and rides cushy.
    71tattooguy and Aqualoon like this.
  4. Jul 29, 2022 at 1:43 PM
    Jer1623
    Jer1623 [OP] Member
    Jeremy
    2021 Tacoma
    honestly it’s more about the look and appearance, I don’t do any off roading really so it all has to do with the look and wider stance. Little bit bigger tire but with that need a little more height
  5. Jul 31, 2022 at 2:31 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    5100s on the 4th setting and a one inch rear block and call it the day. It will yield you about 1 3/4 lift in the front and a 1 inch rear with a slight rake. I did this but added a 1/4 shim/spacer on the driver's side for the taco lean, a ecgs clamshell bushing, front diff and rear carrier drop, Sumo bump stops. Nice budget friendly lift, great ride and priced right.
  6. Aug 20, 2022 at 10:17 PM
    Tacomabro7
    Tacomabro7 Active Member
    2016 Red Tacoma TRD Off-Road 4x4 Automatic
    Hi-line front bumper 305/60R18 tires
    Just ordered the lift kit and it should arrive in a few days. I will keep y’all posted. Since I haven’t found a single person with a good straight answer, I’m going to do Tacomadom a favor and get it and give y’all every piece of info I can. My tires are Nitto Ridge Grappler 305/60r18 (so 12” wide and about 32.4” tall) I currently have a 3 - 2 spacer lift on the truck and my uca hits my coil spring and my upper ball joints are strained so I decided to bite the bullet and get this kit. I’ll keep y’all posted!!
    Edit 1 (8/23/22): I’m just going to put all the info here on the same post so y’all don’t have to scroll to see my posts. I ordered the kit on Saturday at around 11:40pm. The kit shipped the next day and it arrived today, which is Tuesday. Very fast shipping and am very impressed with that! I opened everything and everything looks good; nothing broken or damaged. I plan to install it in about a week or so so I’ll let y’all know when I do that. My only complaint this far is that the rear leaf spring spacers are made of plastic, however they seem plenty beefy enough to do their job properly. If y’all have any questions please let me know!
    Edit 2 (9/1/22): Just installed the lift kit today! I highly recommend using the install video on extremeterrain.com as it is very easy to follow. Install was not as bad as I was expecting. Hardest part is getting the UCA bolts out but even that wasn’t that bad; just bend the pinch weld some. Just make sure you have a buddy to help with the install! ALSO: The alemites in the RC upper control arms were loose! Be sure to check them when you install! I’ve heard some people complain about the RC UCA ball joints failing prematurely but I feel like as long as you keep them greased and don’t over pressurize the boot with grease you should be good. I’ll let y’all know on the condition of the ball joint as time goes by. This lift kit solved my rubbing issue and the ride is better in my opinion than the spacer I had on previously. That’s all for now!
    Edit 3 (2/14/23): Well, bad news guys. After only about 5 1/2 months of having the lift kit on, the upper ball joint boots are starting to dry rot and crack and the left rear N3 shock has already blown and is leaking oil. Rough Country is sending me a new shock out of warranty, but do you really want to replace shocks every few months? I haven't even taken the truck off road! All on-road driving since installation. Truck is parked most of the time yet the kit is still crapping out on me. Don't have the money right now for another lift so I'll limp along with the junk country lift kit until I can afford a 2.5-3" Bilstein 6112 lift kit with 5100s in the rear. Take this as your warning. DO NOT BUY ANY LIFTS OR SUSPENSION COMPONENTS FROM ROUGH COUNTRY. I really wanted to like this lift, but they use the cheapest, worst quality materials they can scavenge. STAY AWAY!
    That's all for now!
  7. Aug 20, 2022 at 10:34 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Everybody not doing any off roading wants bigger tires on their Tacoma? Ya don't go off the road then Ya don't need bigger tires. KISS
    LeakyAC and 71tattooguy like this.
  8. Aug 21, 2022 at 5:59 PM
    FloridaFree
    FloridaFree Well-Known Member
    TRD OffRoad 4x4 mgm
    OME 887 with nitro chargers, icon add a leaf ECGS bearing former 886
    If you do the RC lift you have to drop the diff. they move the front diff down because your coilover is moved down. Do not listen to people here saying not to use diff drop with this lift.
    Looks like a decently designed kit with the way they have the UCA. You gotta make sure the up travel doesn't bump the shocks before the bump stop in the front. I am not sure about the quality of the materials.
    I was looking into emulating something like this
    Tacomabro7 likes this.
  9. Feb 28, 2023 at 9:25 AM
    Stunter808
    Stunter808 Member
    Maui
    2022 TRD Sport 4x4 6M
    Carven Cat-Back Pedal Commander AFE Silver Bullet Injen Evolution CAI
  10. Feb 28, 2023 at 9:27 AM
    Stunter808
    Stunter808 Member
    Maui
    Aloha bro,
    How is your lift doing. Looking to do the same lift but so many haters and bad comments towards it. I'm not looking to do serious off roading. More for fun and looks. Any issues with needle bearing or cv's?
  11. Feb 28, 2023 at 9:28 AM
    Stunter808
    Stunter808 Member
    Maui
    Sorry I'm new to this
  12. Mar 1, 2023 at 8:33 AM
    Sweets
    Sweets Well-Known Member
    Indiana
    2023 GMC Canyon AT4X Edition1
    I've had mine well over a year with no complaints. I did go ahead and replace the needle-bearing when I had them put on, though. From everything I have heard, you have a 50/50 chance of needing it done with any lift.
    polodinks and Stunter808[QUOTED] like this.
  13. Mar 18, 2023 at 9:23 PM
    polodinks
    polodinks Well-Known Member
    Polo
    Florida
    im looking at the same lift seems 50-50 on good and bad experiences
    i might look at other stuff all i want really is decent ride and fit 33's
  14. Mar 19, 2023 at 4:38 AM
    burgershot
    burgershot Well-Known Member
    Did you not read the whole thread? In his update his shit fell apart and he now rightfully refers to the company as ‘junk country’
  15. Mar 19, 2023 at 5:29 PM
    #35
    Stunter808
    Stunter808 Member
    Maui
    Just ordered the RC 3.5 lift with v2 rears. Imma do the ecgs needle bearing since I'm tearing into it. I also wanted to fit 33's possibly on either a 20x10 or 22x10. I like the big rim and smaller sidewall look. I wanted the m1 setup. We'll see how it rides. It'll be here in the next 2 weeks.
    If you read the whole thread, you'd see who I was trying to respond to. His whole kit didn't fall apart. He had a blown shock and a ripped ball joint Bushing. Big deal.
  16. Mar 19, 2023 at 9:47 PM
    #36
    polodinks
    Polo
    Florida
    let me know how it turns out i want to go for a 17 and 33's i wonder if i need to do the ECGS even if the truck is new with 700 miles?
  17. Mar 19, 2023 at 10:18 PM
    #37
    Stunter808
    Stunter808 Member
    Maui
    Mine is new as well. Just about 2500 miles. Imma do it anyway since I'm going that far into it. I'll definitely keep you posted. Check me out on insta
    Elsa_TRD
  18. Mar 22, 2023 at 7:05 AM
    #38
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    20,000 miles on my RC 3.5 Lift and no problems so far. My 2012 had Fox's and I put 220,000 miles
    on those Fox's. I think the RC 3.5 Lift looks great and rides just as good if not better than my Fox's.
    :burnrubber:
    Stunter808 likes this.
  19. Dec 8, 2023 at 1:57 PM
    #39
    claytonketchum
    claytonketchum Member
    Clayton
    Cleveland OH
    2008 Toyota Tacoma Double Cab 4.0L TRD
    Hey, I'm seriously considering this same lift with the rear leaf springs and UCA for 999$. My 2008 Tacoma has 220k on it and it needs all new suspension parts so i figured i would do a lift and get some bigger tires while I'm at it. What are your thoughts on this lift?
    Also, have you had any squeaking coming from your springs? Did you do a "differential drop to make the CV axles happier" as someone ranted about? I was planning on just doing the clamshell bearing right of the bat and a 2.5 degree shim in the back.
  20. Dec 8, 2023 at 2:11 PM
    #40
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Can you elaborate on the harm the diff drop did?
