3.5 rough country lift opinions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jer1623, Jul 25, 2022.
  1. Dec 12, 2023 at 4:57 PM
    #41
    SpeySquatch
    2016 TRD OR DCSB
    rolling the angle of the diff so under certain angles of incline and downhill I had vibrations from fluids not hitting certain areas in the diff…best guess. I’ve heard of you hit the skid hard enough with a diff drop it places the diff closer to the skid and damage can occur to the diff on harder hits.
    Been without a diff drop for years now…it’s unnecessary.
  2. Dec 16, 2023 at 9:58 AM
    #42
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I've read good and bad about them. In my experience (light offroading) never had and issue with the drop installed for the last 16 years. Even with just a 2" lift on my 2nd gen some of the cv boot ribs touch... with the drop they don't. The boots still look like new. Like you mentioned though probably comes down to how you use the truck.
    Sweets and SpeySquatch[QUOTED] like this.
  3. Aug 26, 2024 at 3:38 PM
    #43
    Claytonb
    Claytonb Well-Known Member
    Clayton
    2016 TRD Sport
    6” BDS Lift
    How much of an actual lift did you get out of the rear springs?
  4. May 7, 2025 at 8:17 AM
    #44
    TheDarkTaco
    TheDarkTaco New Member
    2022 SR5
    Tints Dark AF
    Whats your wheel and tire set up? Looks close to something I want to do. Stil fine running
