3.5 V6 ACIS plenum/manifold flap failure (2GR-FKS) SECOND UPDATE
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JohnnyTRD06, Feb 26, 2023.
  1. Jun 8, 2024 at 6:33 PM
    #161
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I’ve only seen one guy that really related to longevity. He had a manual and he installed his SC maybe 3-4 years ago. He was getting a weird screeching noise last year at high rpm that didn’t go away when both belts were removed. The shop he had looking at it didn’t figure it out while he owned it. He traded it. That’s only one scenario but it was enough to make me not want to install one anymore. I’d rather install a new intake every 100K for $600 each as preventative maintenance.
  2. Jun 8, 2024 at 7:07 PM
    #162
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    I’m not feeling this motor will like boost with an open deck and almost 12.0 to 1 compression. It ain’t no 2JZ.
    danielgonzzz, auskip07 and CygnusX191 like this.
  3. Jun 8, 2024 at 7:12 PM
    #163
    PoolFixer
    PoolFixer Well-Known Member
    22 MGM AC SR5 V6 2WD
    OEM TRD headlights, bed lights
    Yeah I might end up doing the same. It seems those plastic bits get brittle with age and I plan on keeping my truck for a long time. I'll go by years instead of miles though, I've only got 3k miles on my 22 lol.
  4. Jun 8, 2024 at 7:13 PM
    #164
    BLtheP
    Plano, TX
    Tight ring gap too. Just doesn’t really seem like a good idea.
    CygnusX191 and Rusty66[QUOTED] like this.
  5. Jun 8, 2024 at 7:19 PM
    #165
    Rusty66
    Rhode Island
    Lotus used a version of the motor that was supercharged (2GR-FZE) but I know little about the reliability of it. I think it was 350+ hp.
    CygnusX191 likes this.
  6. Jun 8, 2024 at 7:20 PM
    #166
    TheWildMan
    TheWildMan Well-Known Member
    3rd Gen 23 Tacoma OR
    Scrubbed some tires, and knocked a dent out.
    Man, Ill be honest I cant necessarily point you to specific threads. Theres a few for sure. I remember one about magnuson tips tricks (etc) and definitely a few other build threads Ive come across where some one SC their tacoma. Im not in any way saying that if you SC your tacoma your fucked, but I know Ive read a bunch of threads where I got the impression that SC my truck would cost more than installing one. I seriously considered adding one to my truck, but from what I came across I couldnt afford the SC plus whatever else was needed.
    Obviously all anecdotal and I cant even provide you with links so...
  7. Jun 8, 2024 at 9:20 PM
    #167
    Stigman
    Stigman Well-Known Member
    2020 Cement TRD OffRoad
    Respectfully… you guys have no idea what you are talking about when it comes to the reliability of the Magnusson supercharger, the compression ratio of the 3.5, wether or not it can handle boost, etc. You read a thread somewhere.
    Alex281 likes this.
  8. Jun 8, 2024 at 10:03 PM
    #168
    BLtheP
    Plano, TX
    I originally wrote a longer response to this but deleted it because I felt it was distracting from the purpose of the thread which isn’t about superchargers. I will say solving the $600 intake manifold problem with a $7K (more like $10K) supercharger is worse guy math than me spending $6.5K on gears and a transmission to fix the relatively minor gearing complaints I have.
    That said, find some long term reviews that are high miles. I looked and saw none. The one guy I mentioned said he has about 60K. That was the most miles I saw mentioned in any threads. I checked his posts from install to trade and it was right at 3 years, Oct 2020 to Oct 2023. That is one example and is nothing to prove reliability, but it does prove some unreliability with his engine no longer idling properly and also making whatever screeching noise he had at 6K rpm. Everybody else I found talking about miles were at maybe 30-35K. Not much longevity discussion at all. The threads are more about “wow! I just installed a supercharger and it’s amazing!” and not so much “wow, my supercharger has been amazing for 100K miles with no trouble!” Compression ratio is 11.8:1, nearly 12:1, so not sure what that comment is about. Ring gap is very tight on this motor, on most boosted engines it is left loose for heat expansion under boost. Plain and simple, the motor is not designed for boost. Whether it can handle it is one thing, but it was not designed with it in mind. It may hold up, it may not. Nobody’s trying to stop you from making the gamble.
  9. Jun 8, 2024 at 10:21 PM
    #169
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    Except that Toyota offered a factory super charger option until recently.
    https://www.cars.com/articles/toyota-discontinues-trd-supercharger-454344
  10. Jun 8, 2024 at 10:39 PM
    #170
    PoolFixer
    Fill us in!
    CygnusX191 and Rusty66 like this.
  11. Jun 9, 2024 at 8:34 AM
    #171
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    That was regarding the 1GR supercharger, which up through 2013 was a factory option on certain TRD builds.
    Offered as a standalone (but compatible) kit 2014+, and ended in 2019 ish.
    Definitely cool, but definitely a different engine lol.
    Barsoom, RDT415 and Rusty66 like this.
  12. Jun 29, 2024 at 11:38 AM
    #172
    JosueRD1989
    JosueRD1989 Well-Known Member
    Hello Guys,
    +1 more broken actuator here! Only down ~$500-600 of parts and diagnostics overall before finding this saving grace!
    Happened after coming back from a Cross Country trip where one day we went to Chicken Corners, probably the day the flap broke off.
    ****Misfire cylinder #3, Random Misfire, CEL, and all the symptoms mentioned as far as limp mode after fast acceleration.
    • First mechanic figured it was a bad valve but recommended we kept driving and got it in to a mechanic to go deeper since he was booked up for weeks.
    • I came back and started replacing smaller tad bits just in case.
      • Replaced Spark Plug, Replaced CPS just in case, checked a few other things but it would still go into limp mode after CEL came on at hard acceleration
    • 2nd Mechanic replaced a Coil, and thought that was it.
      • I pushed it and it happened again.
    • Found this saving forums and took off intake to check myself
      • Immediately heard this was IT!!!
      • Removed the flap and initial cog (See below)
    HELP: Am i missing any parts that could have fell in??? See pictures below? Should I have removed anymore from the pictures after closing it back up???
    - And as someone asked, what does this ACIS flap do and do i need it?
    THANKS EVERYONE!!!
  13. Jun 29, 2024 at 11:39 AM
    #173
    JosueRD1989
    jdjones and CygnusX191 like this.
  14. Jun 29, 2024 at 11:47 AM
    #174
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Looks like your missing the spacer mentioned in earlier post. Probably hanging around a valve per the post above
    VB25, CygnusX191 and Rusty66 like this.
  15. Jun 29, 2024 at 11:50 AM
    #175
    JosueRD1989
    Thank you!
    - How likely would it be that it actually falls further down? Wouldn't the valve keep it from falling deeper?
    - Anyone know whether leaving it if I can find it, will it be ok or is there much risk to it?
  16. Jun 29, 2024 at 11:56 AM
    #176
    Rusty66
    Rhode Island
    You’ll definitely want to remove it.
    VB25, CygnusX191 and auskip07 like this.
  17. Jun 29, 2024 at 11:57 AM
    #177
    auskip07
    Skip
    Atlanta, Ga
    I would get a camera and magnet extension from harbor freight and fish it out. I wouldnt tempt fate if the valve somehow flattened it enough to wedge itself into the valve travel you will have combustion gases pushing through the intake
  18. Jun 29, 2024 at 1:10 PM
    #178
    eurowner
    eurowner Duke Sky
    Scoty
    What year? Mileage? Did you buy it new?
  19. Jul 2, 2024 at 11:18 AM
    #179
    JosueRD1989
    2017 Tacoma Pro
    - 119K miles, 99% daily driver
    - Was off roading at Chicken Corners when I am sure it happened.
    - I bought it used about 5 years ago, when it only had 40K miles or so.
  20. Jul 24, 2024 at 4:29 PM
    #180
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    Good info here
