3.5 V6 ACIS plenum/manifold flap failure (2GR-FKS) SECOND UPDATE
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JohnnyTRD06, Feb 26, 2023.
  1. Feb 26, 2023 at 3:18 AM
    JohnnyTRD06
    JohnnyTRD06 [OP] Well-Known Member
    2017 Tacoma TRD Pro
    Smoked WeatherTec rain guards Access roll up bed cover Tinted front side windows TRD Cold air intake TRD Billet oil fill cap Spartan X Customs hood scoop lightbar Meso Customs dual mode LED interior lights Meso Customs V1 mirror turn signal lights Meso Customs sequential taillights Meso Customs puddle lights and switch kit Putco Nitro Lux LED headlights CBI Off-Road rear skid plate CBI Off-Road gas tank skid plate Kicker DS series door speakers Kicker dash tweeters Overland Tailor Tuning tune
    I'm posting this up under it's own thread to hopefully get this info spread out a little bit more.
    Yesterday I had this ACIS (Acoustic Control Induction System) failure occur on my truck, and fortunately, I was able to find some info about this happening because a friend had actually had it happen to him.
    Im curious to see how common this is going to be, as I saw at least 5 or 6 other people with this exact issue in another thread.
    Basically what happened to me was I was going to merge onto the highway, I stepped on it to get on the highway, and after 4 grand, it started to miss a bit, then instantly went into limp mode. Pulled over, turned it off.
    When I restarted it it was fine....which was odd....it then drove perfectly normal....until I stepped on the gas and it revved up high again
    It started missing and went into limp mode....this time throwing a CEL for PO303, cylinder 3 misfire.
    I swapped #1 and #3 coil packs, and then drove it again.
    After a bit, it did it again, went into limp mode and threw a PO303 cylinder 3 misfire.
    Obviously that eliminated the possibility it was the coil. I remembered a friend of mine had a very similar issue with his Tacoma. His did what mine is did,ran fine at lower rpms, and broke up above 4k..went into limp mode.
    He told me to pulled the intake....and lo & behold....the same problem he had. The ACIS intake flap snapped off and was bouncing around the intake manifold, most likely plugging #3 intake runner under full throttle, causing the misfire.
    After some digging around on here, I found this thread and that this is becoming a more common issue, with everyone here all having the same broken ACIS plenum flap....and the only fix is to replace the entire upper manifold/plenum.
    The intake manifold part number is 17190-0P101 and I got mine through McGeorge Toyota for around $600 shipped.
    PXL_20230226_033406985.jpg PXL_20230226_033107751.jpg PXL_20230226_032824451.jpg PXL_20230226_032817433.jpg
  2. Feb 26, 2023 at 4:07 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
  3. Feb 26, 2023 at 4:11 AM
    JohnnyTRD06
    2017 Tacoma TRD Pro
    Your thread is actually the one I found that helped confirm my issue, along with what my one friend had gone through and told me about.....so thank you for making one of very few sources of info about this issue. That's why I decided to spread this around as much as I can too. Hopefully someone else can benefit from it.
    Yeah, this forum has proven to be a life (and money) saver for a second time for me.
  4. Feb 26, 2023 at 4:22 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Thank you for sharing . Subbed for future reference .
    So this thing breaks eventually when flooring the pedal rpms reaching 4t suddenly like someone kicks a door open and the hinges break. Maybe Toyota replace this with aluminum . Anyway thank you again for sharing
  5. Feb 26, 2023 at 4:43 AM
    willtill
    Maryland
    Not sure why the shaft breaks. Either the ACIS actuator mechanism is not clocked properly when installed, or the door itself is hitting a hard stop excessively at the end of it's full range of motion, subsequently snapping the shaft in half after repeated articulation with full throttle.
  6. Feb 26, 2023 at 5:11 AM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    @ColoradoTJ , hoping you might add this to your helpful thread “2GR-FKS Engine Problem/Failure” . This will be of great resource for us 3rd gen owners as we all know it’s a hit or miss at the dealership . They seldom do real troubleshooting anymore. Thanks.
    KY_Rob, TacoSR523, slinkz419 and 7 others like this.
  7. Feb 26, 2023 at 5:22 AM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    Glad to hear it's an easy fix but rather annoying that it even needed to be done.
  8. Feb 26, 2023 at 5:32 AM
    JohnnyTRD06
    2017 Tacoma TRD Pro
    Yeah, it's one of them stupid little failures that acts like a catastrophic engine failure, lol.....and has proven to be hard to diagnose for dealers.
    CygnusX191 likes this.
  9. Feb 26, 2023 at 5:46 AM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
  10. Feb 26, 2023 at 5:49 AM
    JohnnyTRD06
    2017 Tacoma TRD Pro
  11. Feb 26, 2023 at 5:55 AM
    ColoradoTJ
    Colorado
    Thank you. Mileage and any other information is always helpful. Makes me wonder how many of these "engine failures" was a 600.00 fix? This also makes me wonder if this has actually caused some engine failures?
  12. Feb 26, 2023 at 6:03 AM
    JohnnyTRD06
    2017 Tacoma TRD Pro
    After experiencing the symptoms this causes....Im wondering that myself. For such a small part, it certainly made the truck act like it was blown up.
  13. Feb 26, 2023 at 6:22 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    "Seldom do real troubleshooting anymore"
    Categorically false, most of the time we're looking for problems that the customer poorly described and playing detective at the same time. Sure some guys are lazy and some service writers are sleazy, but at the end of the day, a customers bad review hurts the dealership in the eyes of Toyota, so it's worth it to us to actually do diagnostic work.
    That being said
    I wouldn't have known about this issue if it weren't for this forum.
    :cheers:
    WilliamJames, HisDad, Murd3rd and 8 others like this.
  14. Feb 26, 2023 at 6:24 AM
    ColoradoTJ
    Colorado
    Not to take away from your experience because 600.00 for parts only is still a grip of money. I'm sure this would have been at least 1700.00 had you not done the job yourself.
    I used to R&R new diesel motors on the side for less than what people are paying for used V6 motors.
  15. Feb 26, 2023 at 6:35 AM
    JohnnyTRD06
    2017 Tacoma TRD Pro
    Oh, I'm not complaining it was $600. I'm HAPPY it's only $600! I honestly thought it dropped a valve after I moved coils and the misfire stayed the same.
    I will gladly pay $600 all day for an intake manifold instead of $6000 for a new motor.
  16. Feb 26, 2023 at 6:40 AM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    Bummer you had it happen to you - as some have posted it is and has been a brewing issue - more like a design failure and manufacturing failure on Toyota's part. I took mine off when I installed a Magnuson Supercharger - it along with the upper and lower intake are sitting in a box never to be used again unless I sell them. Fortunately the removal and install of those parts is simple. Glad you got it taken care of and shared part numbers with others so they may not be further taken for a ride by their local stealer. FYI - the ACIS is electronically actuated by the ECU around 3500 rpm when under load.
  17. Feb 26, 2023 at 6:45 AM
    Drippy4x4
    Drippy4x4 Keeper of the Air Dam
    '22 SR5 Taco
    Realistically speaking, wouldn't the new intake you replaced will end up having the same issue again? Manufacturer defect?
    I wonder if you can just remove the broken flap and throw on new gaskets and sent it...
  18. Feb 26, 2023 at 6:49 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    my understanding is this engine is used on other models. does anyone know if this issue occurs on other models, or just the tacoma? if just the tacoma, why?
  19. Feb 26, 2023 at 6:50 AM
    JohnnyTRD06
    2017 Tacoma TRD Pro
    Unfortunately, it's a possibility.
    Also unfortunately, you cannot access the flap if it's intact. The back plate that retains the flap is plastic welded/melted into place on the manifold, so its non serviceable. The only option is to replace the whole manifold.
    GilbertOz, SR-71A, shakerhood and 2 others like this.
  20. Feb 26, 2023 at 11:55 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    ACIS activates as lower as 2600rpms. I've see it activating even lower.
    Nothing to do with flooring
