3.5 V6 vs the 4.0
Discussion in '3rd Gen. Tacomas (2016-2023)' started by peiscooter, Jan 4, 2021.
  1. Jan 4, 2021 at 5:26 PM
    #81
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Impressive man, keep that bad boy!
    I guess its a bit more aerodynamic, so that helps. 3rd gen and 2nd gen is like a brick.
    RocTaco[QUOTED] likes this.
  2. Jan 4, 2021 at 5:33 PM
    #82
    OldManTacoFeels
    OldManTacoFeels The bells of tacos
    Billy Jr.
    2012 DCLB SR5
    Bilstein 5100s, AFE dry intake, Icon AAL pack, Bed stiffeners, and ideally some UCAs soon
    Lololoolololol
    coopcooper likes this.
  3. Jan 4, 2021 at 5:39 PM
    #83
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    There goes another "i drive a proper truck with a truck engine" fella.
    You guys...:facepalm:
    Unless you were just laughing at my meme, i apologize.
  4. Jan 4, 2021 at 5:51 PM
    #84
    Tarl_Cabot
    Tarl_Cabot Well-Known Member
    SC
    Gen 1 2000 2x4 2.7 A/C SR5 Gen 3 2021 4x4 3.5 A/C SR
    says 87 and must be less than 15% ethanol in my 21 manual
    I average about 24 mpg setting cruise at 55 or 65 on flatways, otherwise 16 to 18 going back and forth to Ashville or Sapphire, 20 is "kinda" a base on my norm everyday, soft tonneau gets put in Wednesday
    I have noticed that i get the worse mileage running the crappy Spinx or some other brands (winter mix obviously) compared to the local Walmart down the corner here in SC
    of course i ran my Audi S4 25th Anniversary on the Walmart 93 and always had great mileage and performance....not sure why, fuel quality or mix i assume
  5. Jan 4, 2021 at 6:00 PM
    #85
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    There was a huge debate on here and I mostly run Conoco, Sunoco or Gulf fuel. I ran some 91 when I first got it and it felt a bit different. It seems that the Owners manual lists 87 min octane, while this PDF lists 91 minimum??
  6. Jan 4, 2021 at 7:02 PM
    #86
    Oldtruckguy
    Oldtruckguy Active Member
    2021 White Tacoma OR-AC
    Actually, all four stroke engines hold the valves open during the intake and exhaust cycles to a greater or lesser extent. It’s called valve overlap and is built into the cam timing. Engines with a lot of overlap sound lumpy at an idle and develop a low vacuum signal at idle. The trade off is that they are more efficient at higher engine rpm’s.
    Many modern engines often have variable valve timing controlled by the ECM, allowing the cams to vary the overlap in order to produce a smooth idle and sufficient vacuum at low engine RPM’s while increasing the overlap at higher engine speeds. As I understand it, the Tacoma 3.5 is computer controlled to be a hybrid Otto/Atkinson cycle engine depending on engine load requirements.
    Where I live is very hilly and I have zero complaints about the way the engine or automatic transmission in my 2021 TRD AC OR handles the hills. So far I am averaging just under 19mpg by keeping the freeway speed under 70 mph. I see no practical advantage to screw with the factory tune.
  7. Jan 4, 2021 at 7:09 PM
    #87
    Syncros
    Syncros Well-Known Member
    Last few tanks have been 17.3-17.6 mpg with 265/75R16 E load BF Goodrich KO2s. 60/40 city and highway. It used to average 18.5-18.8 with the P265/75R16 Hankook ATMs. I'd see 22.5-22.9 on long highway trips doing 55-60mph, haven't done a proper one since putting the KO2s on but they are so damn heavy I'm already thinking of replacing them.
    Junkhead[QUOTED] likes this.
  8. Jan 4, 2021 at 7:14 PM
    #88
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    More power, less gas...
    The 3.5 is more efficient.
    Neither are awesome. The program for the 3.5 needs work.
  9. Jan 4, 2021 at 7:37 PM
    #89
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Not bad at all.
    I had stock size E load KO2 and my biggest complaint was they rode like bricks, did not notice an mpg drop to be honest. It was the worst when off road on bumps, they did wear like steel though. C load in an inch bigger size ride like a dream and i still get same advertised mpgs.
    Syncros[QUOTED] likes this.
  10. Jan 4, 2021 at 7:40 PM
    #90
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    The 3.5 is definitely super awesome with the tune :)
    Kolter45 and cropduster78 like this.
  11. Jan 4, 2021 at 7:47 PM
    #91
    Syncros
    They ride terribly, a true 3/4 ton truck tire. Mine are the 3 peak rated version so they wear pretty quickly. They are as heavy as most 285/75R16 mud terrains!
  12. Jan 4, 2021 at 7:58 PM
    #92
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Mine were 3 peak rated as well. The thread looked brand new at 18k miles. Thank god they got prorated due to some premature cracks on the sidewall. Also, one thing i forgot to mention is that they made my truck corner like a sports car with my stock sport suspension. I miss that. I drove a lowered 99 E43 and my taco handled better with the E loads, i was impressed.
  13. Jan 4, 2021 at 8:15 PM
    #93
    Xmplry808
    Xmplry808 Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
    Not sure how the new 3.5 engines are but the 4.0 runs crazy rich, just get a basic tune and you will get better mpg and better hp. Again, not sure how bad the stock tunes are on the 3.5s
    Kolter45 and Junkhead like this.
  14. Jan 4, 2021 at 8:27 PM
    #94
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Maybe that's why the inside of the tailpipe turned black right away on my buddy's 2013 when he got it brand new.
    Some earlier 3rd gen calibrations were pretty shitty apparently. I had no complaints with my 18, it drove great and had good response. The only thing i did not like was the drive by wire dead pedal feel when rev matching. Tune helped with that a bit, also it improved general driveability. I look for every excuse to drive my truck:D
    =JSG= and Xmplry808[QUOTED] like this.
  15. Jan 4, 2021 at 9:11 PM
    #95
    FlamingTacoBro
    FlamingTacoBro Taco Junkie
    So CA
    2012 TRD Sport 2wd DCSB Pyrite Mica
    seems like ALL my Tacos I was getting 14-16 mpg in mixed driving.....and yes I would check the mileage a couple of different ways......but after a while I didn't really care because they were ALL great trucks!.....and YES I drive like a bat outta hell most of the time.....people seem to forget the rules of the road......"slow traffic keep right"......and I would always jackrabbit start.......and going up the toll road usually meant manually downshifting a gear to keep my 80+ mph speed.....oh, and yes I like A/C 24/7...LOL.....BUT, even when I babied the trucks it didn't matter much.....maybe 1or 2 mpg TOPS......they're trucks after all!!.....you buy them to work them and not for Prius like MPG's!
  16. Jan 4, 2021 at 9:20 PM
    #96
    kauaihunter
    kauaihunter Well-Known Member
    Jay
    2021 SR Dbl Cab 4x4 and 2017 SR5 Dbl Cab 2wd
    Kicker speaker upgrade Tint Trimmed air dam Taco Tunes amp and sub 275/70/17 Wildpeaks
    I had an ‘08 TRD and sold it in 2013. Its one of my favorite trucks and wish I kept it. It was completely stock and I got 17mpg all the time with my short runs. Best I ever saw was between 18-19.
    My wife has a 2020 4Runner and it’s a pig but she’s mostly short runs too. I have a 2021 dbl cab and right away on my longer runs I would see up to 21.5. My short runs are running 18.5 to 19.5.
    Easy driving, don’t mash it much at all and don’t need to where I’m from. Apples to apples, I say the 3.5 is more efficient. As always YMMV.
    Junkhead likes this.
  17. Jan 5, 2021 at 3:03 AM
    #97
    Lost In The Dark
    Lost In The Dark Member
    Kevin
    City Of Trees #208
    2019 White TRD Off Road 6M/T 4x4
    Those always use the fuel rated in RON. 91 RON is 87 octane.
  18. Jan 5, 2021 at 3:57 AM
    #98
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    :popcorn::popcorn::popcorn:
    You'll find most of the shit talking about the 3rd Gen is from 2nd Gen members who've never driven the truck.........go figure
  19. Jan 5, 2021 at 4:14 AM
    #99
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    That’s what she said
    Junkhead and Tacoma13_NC[QUOTED] like this.
  20. Jan 5, 2021 at 5:27 AM
    #100
    cropduster78
    cropduster78 Well-Known Member
    NW CT
    '17 DCLB SR5 White
    OV-TUNE 2.0, ADDED/REMOVED STUFF
    I agree a LOT of Gen2 owners/HATERS on here (TW) from the post's I've read don't really know why though....
    Drive em and enjoy em who gives a F either way....
    Junkhead and BlkTaco47[QUOTED] like this.
