3.5L Engine takes a long time to warm up
Discussion in '3rd Gen. Tacomas (2016-2023)' started by James_Bond, Apr 11, 2016.
  1. Apr 11, 2016 at 5:15 PM
    James_Bond
    James_Bond [OP] Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    I'm coming from a 2.7l L4 4runner and this truck takes forever to warm up in the mornings.
    This morning my truck was idling at 1k rpm for 5 minutes and the needle didn't lift up.
    Is this engine this efficient on idle? Is it because I'm used to a big block 4 banger?
  2. Apr 11, 2016 at 5:16 PM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    I don't think my thermostat is stuck open because when I start driving it rises half way and doesn't cool on the freeway.
  3. Apr 11, 2016 at 5:21 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
  4. Apr 11, 2016 at 7:25 PM
    bsacamano
    bsacamano Well-Known Member
    2016 Tacoma Sport DCLB V6 4x4
    More oil in the 6 than 4. Takes longer to warm up. My previous car was an E90 M3. That V8 took 9 freaking quarts. Took forever to warm up.
  5. Apr 11, 2016 at 7:47 PM
    hikerduane
    hikerduane Stove & lantern collector, retired
    Duane
    Meadow Valley, Jefferson USA
    '16 Blazing Blue Pearl TRD Sport AC V6 manual, tow pkg
    RCI sliders fuel tank skid plate, Softopper, tailgate insert
    Mine gets a 30 to 60 second warmup, lots of heat from the heater in under 2 miles doing 25 to 35 MPH, depending on where I'm at. Are you using the heater or relying on the temp gauge?
    Duane
  6. Apr 11, 2016 at 8:37 PM
    FoleySwampPlotts
    FoleySwampPlotts Well-Known Member
    Klint
    Upper Peninsula, Michigan
    '16 MGM Tacoma TRD OR DCSB 4x4 V6 Std Trans
    '16 Tacoma- Avid side steps, LED interior lighting, yaesu ft-2900R VHF radio (KD8EHC), dog box, Garmin Alpha, Plott Hounds Wife's rig '12 Rav4 4x4 4cyl.... its a cupcake, but a damn good runner
    I live in the U.P. of Michigan and according to the temp gauge it takes forever to get its full operating temp but its been pretty damn cold all winter. we'll see if its any different in the summer (if that ever happens up here)
    BMWags likes this.
  7. Apr 11, 2016 at 10:56 PM
    BMWags
    BMWags Well-Known Member
    Brent
    2012 Ford Raptor
    I do enjoy when people 700 miles south of me complain about lack of summer :p
    Snowmobiling must be awesome there too tho. I've heard lots about the UP
  8. Apr 11, 2016 at 11:27 PM
    Pktgumby
    Pktgumby Well-Known Member
    Colorado
    2016 DCSB TRD Sport - Magnetic Gray
  9. Apr 12, 2016 at 5:09 AM
    hikerduane
    Duane
    What's the reason you're mentioning your truck is taking a long time to get to operating temp? Parked outside, not defrosting the windshield? Comparing this scenario between my '93 Toy and my '07 Civic, the Toy was miles ahead of the Civic. The Toy got 28-31 mpg, the Civic 39-40 mpg. If just wanting to get it totally warmed up why worry? Newer engines and oils only require a short run time to get a rollin if not aware. :) But, when changing anti-freeze, the '93 Toy PU was quick to change A-F, the Civic took forever to get the system flushed a few times, warming the coolant a few times to get the system to circulate fresh water.
    My truck so far has been garaged except two nights when backpacking, Spring temps have been in the upper 20's if not close to freezing over night in NV and CA.
    Duane
  10. Apr 12, 2016 at 5:25 AM
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    meh, it warms up just fine this past winter up here in the northern tier. but then again those heated seats warm up in like 15-20 seconds on high and the remote start negates those issues :)
  11. Apr 12, 2016 at 5:49 AM
    hikerduane
    Duane
    I guess I have heated seats, guessing that's what that button on the dash is for. Has not been that cold since I got the truck in mid Feb.
    Duane
  12. Apr 12, 2016 at 5:59 AM
    CravaCrav
    CravaCrav Member
    Eric
    2005 Tacoma Double Cab 4x4 6MT TRD Sport
    If it's hard to hit running temp in the winter, most likely stuck thermostat. Iron blocks will take longer than aluminum, not sure what you have. I had both a 5.9 and 6.7 cummins. I could drive 20 miles to work before it warmed up during cold winter months.
  13. May 10, 2016 at 12:58 AM
    roto prop
    roto prop roto-prop
    Washington
    2016 Tacoma TRD BC DC/OR/LB 4x4 Tow pk , jbl premium
    Dipped front grill , vinyl tail gate letters , vinyl door sill lettering , vled interior lights , Vled back up and license plate lights , Vled switch back turn signals and brake lights , h9 low beam light mod , OEM bed matt , Raised front seats.
    Amsoil makes a cooling system boost additive. It helps the coolant absorb heat better. It heats the water faster and helps to dissipate the heat in the radiator quicker once the engine is at operating temperature. The system should take about 11oz. I just bought some but have not had a chance to add it to my cooling system I will probably add it at the same time that I change my gear box oils to amsoil 75w90 severe gear synthetic oils in the next week or two.
  14. May 10, 2016 at 1:13 AM
    alf
    alf Well-Known Member
    Alf
    Houston
    TRD OR 4x4
    No it doesn't.
  15. May 10, 2016 at 1:44 AM
    95 taco
    95 taco Battle Born
    Diesels in general take longer to warm up because of the higher capacity cooling systems.
  16. May 10, 2016 at 1:56 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    about 5k here now and have never had this issue.
  17. May 10, 2016 at 9:26 AM
    Eric3
    Eric3 Well-Known Member
    So Cal
    2016 Tacoma TRD DCLB Sport
    1976 FJ40
    Thank you OP for asking this question! I don't think this is as much of a warming up question as it is a high idle question. I had a 2015 Tacoma (have no clue why I got rid of it), and at startup in the morning it'd take about 30 secs for the idle to drop to ~600 RPM. This 2016 3.5 seems to take forever for the RPMs to drop. I usually start it up, let it run for about 30 seconds - 1 minute until I hear a slight variation in RPM (or some pump thingy farting), then go. The rest of the day the idle drops pretty fast at startup -- it's just the mornings (or maybe in cold air temp) where it seems the idle never goes down below 1000 RPM. I hope that makes sense.
    Is this "normal". New engine with all kids of weird quirks so just wondering. Mine's been sitting in the shop for a week for a couple other issues so if this is NOT normal I'll ask about it. (though I'll probably be told it's a normal characteristic of the truck)
  18. May 10, 2016 at 11:50 AM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    These trucks have an electronic heater/hybrid. I'm looking at the temp gauge. If I start the truck and let it idle 2 minutes, I have the drive it two miles before the needle goes the 1/4 in the temp gauge. My mornings are not relatively cold, 60F. I live in southern California.
  19. May 10, 2016 at 11:58 AM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    I'm here for the same concern, about the high idle. I don't like a high idle for too long. It adds wear, wastes gas and relatively loud. I would like to know if this is "normal".
    I have had this issue with other cars. What the problem on those cars was the throttle body was dirty. I would take the intake off and wipe it off with a rag dipped in throttle body cleaner. That would fix it.
    This engine on the other hand cannot have had a dirty throttle body. I've been having this issue since I have had it new. Kinda feel like opening a ticket with Toyota at this point.
  20. May 10, 2016 at 12:01 PM
    hikerduane
    Duane
    It quit freezing up north here in Plumas Co. over a week ago or more. Even then, I'd only idle my vehicles a minute or so, depends. Taking it easy the first mile or so. A high idle at start up is to get the catalytic converter heated up. It's not like the old days. Hope I'm not bringing up something you know already.
    Duane
