3.5l mpg....
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cameron knust, Oct 2, 2017.
  1. Oct 8, 2017 at 5:33 PM
    #141
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    Thanks! Good to know.
    I haven't had any diesels since the late 80's early 90's, and that was all in earth moving equipment, and a Mack Tri-Axle. The new emissions equipment makes me nervous over the long haul....by the sounds of things it can't even make for the short haul.
    Getting 20 mpg give or take in the Tacoma ain't so bad in the grand scheme of things.
  2. Oct 13, 2017 at 11:26 AM
    #142
    cameron knust
    cameron knust [OP] Well-Known Member
    took my truck to Elmore toyota to do a service and see whatsup. lol they returned my truck with the battery not properly tightened and mounted. drove 20 miles before i lost total power. check under the hood my battery mount snapped in half and the battery positive side was just inches away from hitting my cylinder and my damn ground wire was literally free floating. they returned the vehicle saying no issues........... well found out why my shits abnormal myself battery connection.... thanks elmore toyota and michael horton for almost catching my vehicle on fire.
  3. Oct 21, 2017 at 5:23 AM
    #143
    rrt49
    rrt49 Well-Known Member
    Ron
    2017 Tacoma TRD Off Road
    Tried a tank of 89 octane...no difference.
  4. Oct 21, 2017 at 6:04 AM
    #144
    phsycle
    phsycle Well-Known Member
    CA
    The best way to determine engine efficiency is to fill up and head straight to the highway. Keep that speed to 60-70 mph as steady as possible. You should get 21-23mpg. When you start mixing in City miles, it throws everything off as there are just too many variables.
    rrt49[QUOTED] likes this.
  5. Oct 22, 2017 at 6:03 AM
    #145
    rrt49
    Ron
    10-4 phsycle, I'm doing a 30 mile run today. All on interstate with only two stop lights. I'll report on the results later. One thing I did notice yesterday, on my "apps" screen it shows 16.7-16.8 mpg however, when I turn off the engine the small screen in the middle of the gauge panel shows 19.2....
  6. Oct 22, 2017 at 7:07 AM
    #146
    phsycle
    CA
    Guessing one is a trip or tank MPG and the other is a lifetime MPG. You can change the display setting under “Settings” to set it to the specific MPG you want.
  7. Oct 22, 2017 at 7:18 AM
    #147
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    The mpg that is shown when you shut engine off. That is mpg between ignition on to ignition off. Keep in mind idle time anywhere when truck is not moving takes away from mpg too.
  8. Oct 22, 2017 at 8:08 AM
    #148
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    Problem = 33" tires
  9. Oct 22, 2017 at 8:21 AM
    #149
    SWB Tacoma
    Arkansas
    Run it in 5th on Interstate. See if that helps. 33" tires an 4th might be fine.
    Back in 70's when people started running 38" tires. They had same complaint. Answer was to change gearing.
  10. Oct 22, 2017 at 8:26 AM
    #150
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    let me guess 33 KO2s? Load range E?
    Thats a heavy tire no shit your feeling it in your MPG.
  11. Oct 22, 2017 at 8:37 AM
    #151
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    We’ve been testing some of the single module stuff for Cummins in our 9L trucks with good results. Supposedly it won’t require service like the current DPF/DOC every 150-200k. The $4,000 bill hurts when you get it every third year on all trucks. I’d take a gas engine all day in my personal vehicle over new diesel stuff.
    We’ve got a 2.7 f150 supercab shop truck that gets right at 18-20 mpg. Almost all highway...the truck is fast but it still can’t defy physics like some here think the ecoboost does.
  12. Oct 22, 2017 at 2:18 PM
    #152
    rrt49
    Ron
    OK, put on 60 miles of almost all four lane with only four stop lights...no hard take-offs, stayed between 60 and 70, apps mpg shows 17.1mpg.
    truck has about 1100 miles on it. One of the sales guys at the dealership said his did the same until about 4-5,000 miles then it started getting about 22-23mpg. I think he was just stroking me so I wouldn't bad mouth the trucks economy.
  13. Oct 22, 2017 at 2:23 PM
    #153
    SWB Tacoma
    Arkansas
    Mine consistently get 21-24 on highway depends on how I drive. 6200 miles.
    rrt49 likes this.
  14. Oct 22, 2017 at 2:33 PM
    #154
    keg830
    keg830 Active Member
    16 Black Taco
    Bilstein 5100's all around (2nd Gen) OME 888's in front set at 0 Wheeler's AAL SCS Ray 10's in Gunmetal TRD Pro Grille Baja Designs Squadron amber fogs
    I have 33s too and mine probably dropped about 2-3 MPG (depending on the type of gas I use) but it seems to mostly be from wind resistance on the highway. Now that I have a small lift with bigger tires, if there is a little bit of wind my MPG takes a hit. I average about 18 MPG a tank in Nebraska. Windy, mostly flat, but not high altitude.
  15. Oct 22, 2017 at 8:35 PM
    #155
    smcfarla
    smcfarla Well-Known Member
    CT
    2017 TRD sport, red
    Has anyone noticed improvement with the tailgate down? Twice I've gotten 1-2mpg more. Not sure if it's coincidence or real
  16. Oct 26, 2017 at 10:54 AM
    #156
    mpoirier61
    mpoirier61 Member
    2016 Silver Tacoma Sport
    Extang E-max Tonneau Cover
    OK...I have had my truck since February of 2016 and have 31,000 miles on it.
    Driving highway under 75 mph getting around 21.5 mpg. Normal driving everyday non highway
    60 miles each day getting 25 mpg steady since 20,000 miles. Best tank 26.8 MPG
  17. Oct 26, 2017 at 11:17 AM
    #157
    eurowner
    eurowner Duke Sky
    Scoty
    Lowest has been 14, highest 31.
  18. Oct 31, 2017 at 11:59 AM
    #158
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
    Experimenting with tire inflation on the stock OR Wranglers. Spec 30psi cold gives ~18-19+ mpg at the end of the tank. Upping to 35psi cold gives 20+mpg (pressure rises to 38-39 when warmed up). Probably going to settle on 34psi cold on tarmac, drop to 32psi warm or 30psi cold on gravel and snow.
    I know my old Volvo wagon had 2 tables of tire inflation numbers printed on the door jamb. 32/36 f/r for traction, 36/41 for economy.
    Seems like the extra mileage in gas economy and tread life is worth it. I haven't chalk-tested the tires with or without load.
    Most mileage is 3 person commute, mixed but hilly roads, with an empty bed. Weekend duty is 1 or 2 persons with 50-300lb in the bed, depending on dump, garden, moving, biking or camping duty.
    Still no road trips but I have to go to ATL for business this week, so I'll see some highway mileage.
  19. Nov 1, 2017 at 7:06 AM
    #159
    1cleanFG
    1cleanFG DialsGarage
    DialsGarage
    PNW
    2023 Sport 4x4 DCLB
    Toytec Alumaseries Coilovers OME El111R Camburg UCAs Scs sr8 17” 285/70/17 KO2
    Lowest I’ve seen mixed driving (not towing) was around 16, highest was 23 on a road trip.
    Towing a 20’ Alumaweld freedrifter with the bed loaded with camping gear (Leer canopy as well) from Seattle to Baker lake and back I got 14. No complaints here.
  20. Nov 1, 2017 at 8:43 AM
    #160
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    love those front/rear replacement bumpers, makes it really stand out from the norm.
    on a side note my stats from oct-2015 (bought) to current. this is 95% city driving within a city of 50k and around 20 sq mile radius city. door to door for the wife is about 2-3 miles for work commute. mind you she generously uses the remote start and it gets to -10 to -25F easily during the winter months up here.
