3.5L v6 engine oil level reads high
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hdtacoma2006, Jun 30, 2024.
  1. Jun 30, 2024 at 10:29 AM
    Hdtacoma2006
    Hdtacoma2006 [OP] Member
    06 tacoma sr5
    Hi Everybody ,
    We are wondering if anyone else has experienced a high oil level reading on their 3.5 liter v6 ?
    After changing the oil (0-20 synthetic 6.2 quarts) , our dipstick always reads high . (3/8" + above the top dot on the dip stick)
    Has anyone else had this issue ? We searched here on 'Tacomaworld' and didn't find any answers . Our Tacoma is a 2023 trd .
    Hopefully someone else has experienced this puzzling issue and could share their findings .
    Thank you !
    winnipegbeachtacoma90 and ponts like this.
  2. Jun 30, 2024 at 10:32 AM
    Taco y mas
    Taco y mas Well-Known Member
    SoCal
    Tacoma TRD Sport
    None
    Did you also change the filter?
  3. Jun 30, 2024 at 10:36 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    I put 6 quarts in mine and it’s dead balls on full when the oil is at operating temp.
    22Coma6MT and Jakerou like this.
  4. Jun 30, 2024 at 10:38 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Usually do 6 quarts … u have to remember that even after draining u still will have residual oil left in the engine . You would have tip the truck side to side front to back to get every amount out .u can get a small tube and a syringe of some kind and siphon some out of dipstick . DO NOT DO THIS WITH ENGINE HOT or WARM. ONLY COLD. It can melt in the dipstick tube .
    22Coma6MT and Barsoom like this.
  5. Jun 30, 2024 at 10:44 AM
    Trail Limo
    Trail Limo Well-Known Member
    Wait. Doesn't everyone do this?
    Seriously though. I also fill exactly 6 qts and it's right on the dot oil and filter change.
    Barsoom likes this.
  6. Jun 30, 2024 at 11:09 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Try this, wipe the dipstick and insert into the hole. Wait a couple of hours. Pull the dipstick out and without wiping and see what the level reads. Do this and see if you still get a high reading.
  7. Jun 30, 2024 at 1:11 PM
    Hdtacoma2006
    06 tacoma sr5
    Yes ! I forgot to mention that in my post. Sorry !
  8. Jun 30, 2024 at 1:40 PM
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    Are you measuring right after you put the oil in but before you started the truck? Might be that the oil filter is not filled up.
  9. Jun 30, 2024 at 1:42 PM
    Bishop84
    Bishop84 Well-Known Member
    Check after 5 mins, any longer will always read high.
    I usually get 6.2 liters in 3.5 tacoma, which is 6.5qts apparently.
    Canadian Caber and TnShooter like this.
  10. Jun 30, 2024 at 7:08 PM
    099 Well-Known Member
    2022 White Tacoma Double Cab SR5
    I put 6 and a half quarts. Easy enough. A mechanic once ask me-how muck\h oil is i the pan at 65mph. Never had an issue.
  11. Jul 7, 2024 at 3:05 PM
    Hdtacoma2006
    06 tacoma sr5
    We may have discovered something today regarding our mysteriously high oil readings on our 3.5L V6 Tacoma .
    We found that if we remove the dip-stick and leave it out 5 minutes or so , then check the oil level (only once!) you will have an accurate read .
    It seems the oil is being dragged up into the tube when checking the oil level - thus - following checks read high because the oil within the tube is added to the stick and giving a false and high read . (Hope this makes sense)
    Hopefully everyone had a Great 4th of July and had a chance to take a minute to thank a Vet .
  12. Jul 7, 2024 at 3:37 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Thanks for the info!
    I use Havoline Full Synthetic and measure...it's somewhat high but your suggestion sounds correct.
    TacoMamba35 likes this.
  13. Jul 7, 2024 at 4:06 PM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    you put in too much oil, but it won't hurt anything. it only takes 6 quarts to hit the full mark. as mentioned above, there is residual oil in the engine and pan which is why anything over 6 quarts reads above the full mark.
  14. Jul 7, 2024 at 4:23 PM
    bfonic
    bfonic Well-Known Member
    2023tacoma
    I'm thinking of going 5w-30 just so I can see the dipstick. lol
    Rusty66 and TacoTime55 like this.
  15. Jul 7, 2024 at 4:37 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    OW-20 is on the lite side...lol
    bfonic[QUOTED] likes this.
  16. Jul 7, 2024 at 5:16 PM
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    Yup, that works every time.
  17. Jul 7, 2024 at 6:08 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    I use the same stuff. Love the 6 QT box. I don't even bother with the .2 QT.
    TacoTime55[QUOTED] likes this.
  18. Jul 17, 2024 at 1:09 PM
    ODtheOG
    ODtheOG Well-Known Member
    Mo
    Orange County
    2022 Tacoma TRD OR
    I fill 6.2L in mine.. one time I had to go 6.5.
