3.5L V6 or 4.0 V6 more reliable?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jamesmanee, Feb 1, 2023.
  1. Feb 4, 2023 at 5:20 PM
    #241
    point45
    point45 Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
  2. Feb 4, 2023 at 5:25 PM
    #242
    Fantastic11
    Fantastic11 Well-Known Member
    1997 3.4L 4WD / 1996 3.4L 5-Lug
    3.4 liter is the king ;)
    Superdave1.0, JDKred, robm7 and 3 others like this.
  3. Feb 4, 2023 at 5:29 PM
    #243
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Hahaha!
    Lt. Dangle likes this.
  4. Feb 4, 2023 at 5:38 PM
    #244
    Williston
    Williston Sorta-Known Member
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    :thumbsup: You are correct: 2-shaft Gas Turbine APU manufactured by Pratt & Whitney Canada for the A380. Pratt & Whitney also provided a Turbofan APU for the Boeing 747. Honeywell supplies the APU on the Boeing 777. However: rumor has it on verified authority that the Toyota 2TR-FE 2.7L is/was the standard supplied equipment APU for the plane featured in Top Gun: Maverick...because it never breaks down and you can't kill it. :facepalm:(As proven on "Top Gear")
    Note: Boeing just delivered the last 747 (N863GT) in 55 years of production on February 1st. It is a 747-8F freighter: the 1,574th airplane manufactured.
    Lt. Dangle and Junkhead like this.
  5. Feb 4, 2023 at 6:00 PM
    #245
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Correct…..this is utter BS
    I know this for a fact
    I’ve worked on one before, they look like this below
    Been working aircraft since ‘85
  6. Feb 4, 2023 at 7:55 PM
    #246
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    The 3.5l timing leak is totally preventable, assuming (with a very high probability) it was assembled and torqued in the correct sequence at the factory.
    The problem is the longer OCI, air filter and no PCV valve replacement recommendation at all, that was standard in the past.
    My current 3.5L is seven years old, and there’s not a stain, let alone a seep or leak with over 75k. Valve covers, cam covers, entire motor is the same way, all dry, and it’s due to maintenance.
    I’ve had a 4.0L with 13ys 200k dry as an old bone, same family/design as the 3.5. I have another one still running like new at 10 yrs, no seeps or leaks anywhere. And normally by this time, the average engine shows at least a stain, so it’s not luck. I change my oil every 5k miles, filters and PCV valve every 20k or yearly which ever comes first, no issues.
    To me, it's worth the maintenance, for others, not so much, they don't keep them long.
    GSDLVR123 and Canadian Caber like this.
  7. Feb 5, 2023 at 4:03 AM
    #247
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Have a 4.0 in the FJ
    Changed oil at 500
    Again at 2500, then changed every 3k-5k max
    115k, doesn’t leak or consume a drop
    Oil changes with Mobil 1
    Plan on doing the same with my new Tacoma when it arrives in late march
    enforcertaco91 likes this.
  8. Feb 5, 2023 at 6:22 AM
    #248
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I had a 4.7 tundra with over 290k miles doing oil changes every 15k miles, or more with mobil1, and their filters. I think I replaced the air filter every 50k miles with wix filters. That engine was dusty dirty, but not a single weep of oil, or coolant anywhere. That truck is still being driven by another owner today. This stuff about oil changes, and leaks is bs.
    Chew likes this.
  9. Feb 5, 2023 at 6:50 AM
    #249
    IRONCLADBARREL
    IRONCLADBARREL Active Member
    Rio Grande Valley
    2018 CEMENT TRD OR DCSB
  10. Feb 5, 2023 at 8:06 AM
    #250
    Falconemalcone
    Falconemalcone Member
    Malcolm
    British Columbia, Canada
    2019 OR AC 6M
    You also have the manual transmission which has a better gear ratio. 4.3 I believe. Makes a big difference. There’s a reason a lot of guys with the automatic gear swap when they lift and do bigger tires.
  11. Feb 5, 2023 at 8:17 AM
    #251
    IdeaMan
    IdeaMan Well-Known Member
    Jim
    Fresno, CA
    Barcelona Red 2018 Toyota Tacoma SR DCSB 4x4
    Eibach Pro Truck Lift, Icon RXT Leaf Springs, LT255/80R17 Toyo ATIII, Body Armor Hiline Bumper w/OZ LED Light bar and Smittybuilt X20 Synthetic Winch, TRD Pro Skid plate, Shrockworks Sliders/steps, bed mat, some interior storage accessories, cell phone mount, and blacked out emblems.
    How often do you change the oil?
  12. Feb 5, 2023 at 11:52 AM
    #252
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    :amen:
    I kinda feel like jumping in their section just to throw some shade…and I won’t wait till it’s Friday :bananadance:
    shakerhood, Junkhead[QUOTED] and Chew like this.
  13. Feb 5, 2023 at 12:45 PM
    #253
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
  14. Feb 5, 2023 at 1:05 PM
    #254
    Williston
    Ummmmm: Help me out here. :confused: Re: "3rd Gen": 3rd gen what ??? Which brand/make/company are you talking about here? "Motors going out" Yugo?/Fiat?/1970's Ramblers/Ford Pinto/Chevy Chevette/Vega??? Maybe it's the windshield-washer motor that's going out every week.
    No wait: Almost forgot: Anything made by Renault ? I'm confused: I don't think I have ever seen a post here titled: 3rd gen: motor out, electrical failure, "leakage up top"... new guy another 100K motor gone...."
    Junkhead and Chew like this.
  15. Feb 6, 2023 at 5:45 AM
    #255
    bigoldbeef
    bigoldbeef Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    from new - 180k I did every 10k
    185k - present I’ve been doing every 5k
    Junkhead likes this.
  16. Feb 6, 2023 at 7:49 AM
    #256
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    This is kinda like Mayonnaise fights..
    Dukes or Hellmann's :duel:
  17. Feb 6, 2023 at 8:58 AM
    #257
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Plenty have gotten the leak with 5k OCI
    Our fleet trucks at work are a mix of 17 and 18 3.5 tacomas. 10-15k oil changes with cheapo synthetic. No one's is leaking yet. Some are over 100k.
    Toyota is well aware of this issue and I would bet they know exactly why. They may never tell us but if it was as simple and an OCI and or PCV valve issue, they would make a correction.
  18. Feb 6, 2023 at 9:12 AM
    #258
    The hammer
    That may be true, and I reiterate, "The 3.5l timing leak is totally preventable, assuming (with a very high probability) it was assembled and torqued in the correct sequence at the factory."
  19. Feb 6, 2023 at 9:18 AM
    #259
    fourfourone
    I get that's your opinion, but I disagree. After being a service manager for 10 plus years, I have never seen a clogged PCV or 10k OCI cause the timing cover to leak on a Toyota or any other brand.
    Without knowing 100% I wouldn't be telling everyone on here that its preventable when you really don't know if that's true or not.
    DavesTaco68 likes this.
  20. Feb 6, 2023 at 9:20 AM
    #260
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Both suck!
    :crapstorm:
    redneck pilot and Lt. Dangle like this.
