3.5L V6 or 4.0 V6 more reliable?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jamesmanee, Feb 1, 2023.
  1. Feb 7, 2023 at 1:15 PM
    #321
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Going back some to a head leak our shop had in a fairly new 305 gmc truck. The dealership replaced the head gasket in warranty yet it still leaked a week later. Took it back, and asked them if they checked for a warped head. It was like a light bulb lit up. They never did saying this was a new truck, new engine, it's not likely. Sure enough warped head. :frusty:
  2. Feb 7, 2023 at 7:33 PM
    #322
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
  3. Feb 26, 2023 at 9:36 AM
    #323
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Holy crap what year? Any oil leaks or issues?
  4. Feb 26, 2023 at 9:43 AM
    #324
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    4.0>3.5
  5. Feb 26, 2023 at 9:45 AM
    #325
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    this shit again
    #trollpost
    shakerhood likes this.
  6. Feb 26, 2023 at 10:35 AM
    #326
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Waiting for the mushroom 2.7 guy to post
    Junkhead, Gfenza89 and Canadian Caber like this.
  7. Feb 26, 2023 at 11:03 AM
    #327
    turbosnail
    turbosnail Well-Known Member
    Pa
    18 dbl cab sr5 v6 4x4 , 1985 turbo sr5 pick up
    2.7> Ezra
    Junkhead, LeakyAC and Lt. Dangle like this.
  8. Feb 26, 2023 at 11:19 AM
    #328
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Same basic motor as far as I know.
    Only the stroke is different other then the injection system and valve train. They are both fine. The 4.0 has much better low end torque which means it will run at lower rpm more often perhaps giving it a slight edge in longevity. My wife has the 3.5 in the venza and I have the 4.0 in a 2015 Tacoma. Have driven the newer motor. Love it in my wife’s car, hate it in the 2016 plus truck. My nod is the 4.0, but there are many other things about the newer generation you might like better, like handling, electronics etc. Overall, I wouldn’t let the motor be the deciding factor till you drive a newer one for an extended time.
  9. Feb 26, 2023 at 11:23 AM
    #329
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    :rofl:
  10. Feb 26, 2023 at 11:23 AM
    #330
    Chew
    Chewy
    Midwest
    19 TRD OR
    OP never replied, just lit this shitbag and logs back on to check on his work.
    Junkhead, Deeahgee, alwaysHI and 5 others like this.
  11. Feb 26, 2023 at 1:59 PM
    #331
    Gfenza89
    I don’t know man I don’t think it’s possible to beat the 2.7 in long term reliable
    Junkhead, faawrenchbndr and LeakyAC like this.
  12. Feb 26, 2023 at 3:32 PM
    #332
    maxmk8
    That’s not the point
    Junkhead and Lt. Dangle like this.
  13. Feb 26, 2023 at 4:15 PM
    #333
    Gfenza89
    Don’t get me wrong I think the 2grfks is a bulletproof engine certainly just as good as the 4.0
    Junkhead likes this.
  14. Feb 26, 2023 at 5:11 PM
    #334
    maxmk8
    It’s more about that particular member and less so the engine compare.
    You can ask about something trivial like best spark plug for the 3.5… and his answer will be. “Yo I thought the 3.5 doesn’t need spark plugs, should have gotten the 2.7”
  15. Feb 26, 2023 at 8:40 PM
    #335
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The factory service manual does not say to remove the engine. It does say to remove the oil pan, but it only has you remove the steering rack and front differential (if 4WD) to get to the oil pan. The engine stays in the truck.
    Toyota uses the same OCI for the 3.5L and the 4.0L for the same years, used to be 5,000 miles, now it's 10,000 miles, for both.
    Toyota has never had the PCV valve listed as a maintenance item, at least not for the last 40 years.
    There actually were timing cover leaks on the 4.0 as well, in fact there is a TSB for 2005-2008 Tacomas with the 1GR to repair a leaking timing cover.
    Jeff
  16. Oct 16, 2023 at 3:53 PM
    #336
    LilTexan22
    LilTexan22 Well-Known Member
    2017 Tacoma
    Thats because all years of 3.5 are years to avoid
  17. Oct 16, 2023 at 4:00 PM
    #337
    Bishop84
    Bishop84 Well-Known Member
    Post from February and you felt the need to bump with this? lol
  18. Oct 16, 2023 at 4:53 PM
    #338
    Lt. Dangle
    Ohio
    Dude doesn't even have a 3.5. Or a funny bone.
    shakerhood, Junkhead and Chew like this.
  19. Oct 16, 2023 at 4:56 PM
    #339
    Gfenza89
    Gtfo you’re insane. 3.5 is a great engine sure has its quirks like any other engine
  20. Oct 16, 2023 at 5:02 PM
    #340
    LilTexan22
    2017 Tacoma
    3.5 was the worst v6 they put in a tacoma
