3.5L V6 vs 4.0L V6
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GONE HAWKIN, Aug 4, 2017.
  1. Sep 16, 2017 at 7:20 PM
    #221
    Syncros
    Syncros Well-Known Member
    They are under rated if you ask me. I've been thinking about replacing my 2010 with a loaded 2017 CCSB 5AT Pro-4x. It's that or a 2017 4runner TRD OR but there's an $11k price difference.
  2. Sep 17, 2017 at 12:55 AM
    #222
    duckytw
    duckytw Well-Known Member
    We missed our chance on a v8-- back when the Tundra was V6, the 4Runner had a V8, and even the lowly rav4 could be had with a V6-- not to mention TRD was slapping a supercharger on just about anything and selling you a $50 radiator cap. Now Im happy Tacoma is keeping a 6 in the face of everyone doing turbos, even pairing it with a 6mt, but damn, it does need a bit more time in the oven IMHO to get the tuning sorted. Its like the engineer in charge said, "heres the new camry engine you asked for-- oops".
    specter208 and Steadfast like this.
  3. Nov 11, 2017 at 3:01 PM
    #223
    BillyToy
    BillyToy Well-Known Member
    PNW
    2017 Tacoma TRD Pro 6MT
    You've nailed it, and not "but still". It's all about the MT, especially with the 3.5L (I don't know about the 4.0L auto vs. manual). So far, my experience has been that this engine just likes to be in it's happy place which is 3500+RPMs. Keeping it in the sweet torque band with a manual transmission = happiness. I suppose you've heard of the OVTune ECU mod...
    specter208 likes this.
  4. Nov 11, 2017 at 3:08 PM
    #224
    NerdTaco
    NerdTaco Well-Known Member
    I’d have loved if Toyota had put the 5th gen 4Runner engine in the 3rd Gen Tacoma. It’s weird how the Tacoma never got that engine. More torque and more horsepower than the old 2nd gen 4.0, and none of the weirdness that the new 3.5 Tacoma has.
    Vonhetzer and Key-Rei like this.
  5. Nov 11, 2017 at 3:30 PM
    #225
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I'm thinking the T4R will get the 3.5 when it's redesigned. Toyota probably wants to do away with the 4.0 eventually, right or wrong (and that's why the 3rd gen didn't get it).
  6. Nov 11, 2017 at 3:41 PM
    #226
    mavfox
    mavfox Well-Known Member
    SFL
    2013 AC TRDOR/07 FJC
    ARB Deluxe bullbar, OME 886 w/ Dakars, Warn Winch, Safari Snorkel, Tepui RTT.
    4.slow all day!!!!!!!
  7. Nov 11, 2017 at 9:17 PM
    #227
    wall-e
    wall-e Well-Known Member
    NW WASHINGTON
    RED TRD PRO
    HID Headlights, SnugTop GB Sport Canopy
    The 3.5L engine is a good engine. I had a 08 Tundra crewmax with the 5.7L that I just traded in on my new Tacoma. While 3.5L is no 5.7L, it gets the job done and is no slouch. I don't mind the transmission in my new Tacoma. My 08 Tundra's transmission really use to hunt for gears. It also had an issue when it would go into second gear, which I never got used to. My 5.7L had to have the water pump and radiator replaced. Furthermore, the air injection pumps for it went bad and were replaced under warranty. I hope I have better luck with my new Tacoma, although I did own my Tundra for 10 years.
    Stocklocker likes this.
  8. Jun 6, 2018 at 9:53 AM
    #228
    MarcoTaco
    MarcoTaco Active Member
    Mark
    South Maryland
    2017 TRD Sport Taco 4x4 Acc Cab A/T V6
    Hellwig rear leaf, BFG 265/70 KO2 tires, Method rims, Bilstein 5100 frt struts, OVT
    IMO - the 4.0L was a truly great engine. I had a supercharged 3.4L engine in my previous truck and when the 4.0 was born - it seemed a nice upgrade. But the 3.5L may be even better, in a few "small" ways. I can't say that having 2 injectors per cylinder is an improvement, (since it is twice the components, etc. for maintainability). Its virtual "Atkinson cycle" combustion is a neat idea too - but my bottom line for satisfaction is "WHAT" an engine does, rather than "HOW" it's done.
    So that increase up to 278 HP is what caught my attention, (even though it has about 1 Ft/Lbs LESS torque than the 4.0L predecessor). Mileage is very dependent on your foot. Personally, I usually drive like I want to get there - so mine ranges from 18 to 20 mpg - on my 20 mile "commute" on average. On a longer trip, 23 has happened, but on a short run with my foot down, I have seen 16.5 mpg.
    If I had to select/amplify a single fault in the truck, it will be the shift points programmed in the transmission control, (6 speed auto). In the "norm" mode, it yields economy - and keeps you from spinning tires on a wet road when "starting off" after a stop. But when you want to get on it from a 40 mph cruise - like to pass another vehicle - it seems as if the downshift is too long "coming" - or you need to reach down "too far" to get it. But make no mistake - it "goes" - when you make it go - especially when you engaged that ECT switch. I also wish that switch was located up on the dash or steering wheel AND that electrically, it remained latched, when depressed, (so stopping/starting the engine doesn't reset it back to economy mode by default. But again - just IMHO.
    Now with that ECT button engaged, (sport mode?) it extends those shift points in RPM. Yet at times, I feel like it should shift into that next gear instead of continuing to wind out - but this is again just my opinion. As I hinted - It runs like a bat when you launch it in this mode.
    My general rating of the truck, (strength in pulling, cruising, acceleration, speed, comfort, handling, braking, steering) - and of course the "looks" - are all great. (I now have just under 9K on it as a reference). On wet roads, it often breaks traction in the rear under medium acceleration, so watch your traction light. I sometimes run in 4WD (H) in the rain, (when in a hurry) during the rain - where traffic lights cause repeated stop/go's.
    I hope that Toyota may have been able to resolve some of these small mentioned items in the 2018 model, but I haven't seen or heard as yet. Anyway - sorry for the novel. But I like to give info that might help someone if possible.
  9. Oct 8, 2018 at 12:35 AM
    #229
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    What's the advantage to having mote torque around 4K rpm as opposed to 2k?
  10. Oct 8, 2018 at 2:15 AM
    #230
    SouthtownTaco
    SouthtownTaco Well-Known Member
    San Antonio, TX
    2016 TRD Offroad
    RCI Under Armor, Tailgate Lock, Bakflip F1, derped grill
    I agree and think everyone would agree that we would all prefer more low end torque on any engine. Toyota's stock tune leaves 3.5 owners wanting more and OVTune awakens low end torque nicely.
  11. Oct 8, 2018 at 5:26 AM
    #231
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    Still don't know why you would want a high revving motor in a truck where you need the power in the low RPM range. What's the point if your smashing over 4K rpms just to move. There goes your fuel mileage. Its also rated lower for power than most of the other vehicles using the 3.5L. If I drove off-road only it wouldn't be so bad since the torque is there due to the transfer case. But on-road, this thing is straight dick, even after the TSB. It is awful to drive in city driving as it always hunts for gears and shifts constantly. Rolling stops and then going at like 3mph it will shift 4-5 times from there to 10mph with a good second delay then clunk, clunk into gear. Goes 3rd-2nd-1st-2nd-3rd. in like a 500 rpm range. Also you need a good window to pull out from a dead stop since the truck just sits there thinking WTF it wants to do. I do love the truck but this is the worst engine/trans combo I've run in over 40 vehicles. OVtune seems to fix it, just cant see spending that type of money on a tune for a NA vehicle. The ECT is a joke, its just an OD button like cars years ago had on the shifter. Makes it even clunkier to shift. I haven't driven the 4.0, but I cannot see how any motor/trans could be more annoying than the 3.5L setup.
    SouthtownTaco likes this.
  12. Oct 8, 2018 at 5:32 AM
    #232
    unavailableTaco
    unavailableTaco Well-Known Member
    Roy
    Grapevine Texas
    2018 Tacoma TRD PRO
    Full tank of gas
    I think Toyota saying to change the plugs on the 4.0 was just a profit deal because they made more V6's then the 4cyl. The 4cyl was specified to change them at 100,000 miles. I did not change mine in the 4.0 and it had 85k miles and at idle in drive I could not even feel the engine running. I was going to change them at 100k but then it got totalled so I will never know.
  13. Mar 6, 2019 at 5:49 PM
    #233
    Land cruisers & Tacos
    Land cruisers & Tacos Member
    Az
    65 Fj45 68 Fj40 98 taco 19 taco
    Wow, seriously
    Just bought a 19 taco. I skipped the 2nd gen. I personally never liked the looks or how they drove ( just my opinion). My 19 gets 21-25.7 mpg and seems more agile, nicer interior, better tech etc. The 4.0 liter is too thirsty IMO, but they are reliable. All of my trucks are 4x4. PS, the 3rd gen has 10% lower low range, doesn't that help with torque??
    Paul631 and Flash1034 like this.
  14. Mar 6, 2019 at 7:57 PM
    #234
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
  15. Mar 6, 2019 at 8:00 PM
    #235
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    o_O:facepalm:
  16. Mar 6, 2019 at 8:04 PM
    #236
    SpeySquatch
    2016 TRD OR DCSB
    If you get a new one get OVtune also otherwise the driving experience will be sub-par...especially in traffic
    TacomaSport86 likes this.
  17. Mar 6, 2019 at 8:05 PM
    #237
    SpeySquatch
    2016 TRD OR DCSB
    I’d keep it. Too much time with it
  18. Mar 8, 2019 at 7:34 AM
    #238
    Vonhetzer
    Vonhetzer Well-Known Member
    IN
    19 Taco
    Holy old post revival Batman! Just drove back to back yesterday from my 3.5 to my wife’s 4.0 in the 4Runner. 4.0 is definitely better, seats are more comfy also.
  19. Mar 8, 2019 at 7:50 AM
    #239
    BBPSR54X4
    BBPSR54X4 Well-Known Member
    2017 SR5 DCSB 4x4
    I went from a 2000 T4R 3.4 V6/Auto to my 2017 Tacoma 3.5 V6/Auto.
    No doubt about it, I noticed immediately that the go pedal just didn't seem the same. I had to adjust to have a heavier foot.
    That said, I am not the fastest off the line or the slowest. But I can make the Taco go the way I want it to.
    The other issue is the downshift when you are under way and stomp on it to pass someone (or similar).
    The downshift does feel overly pronounced (and awkward), but once again I can make the Taco go the way I want it to.
    The best thing is despite being bigger and heavier, the Taco gets better gas mileage than the T4R in every driving condition.
    It's good but not perfect.
  20. Mar 8, 2019 at 8:04 AM
    #240
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    The 3.5 is just fine. It's going to drive different though.
    BRFab, deuceb, SpeySquatch and 2 others like this.
