3.6L S/C Low Boost Pressure Problems
Discussion in 'Performance and Tuning' started by jarondenson, Sep 18, 2011.
  1. Sep 18, 2011 at 2:55 PM
    jarondenson
    jarondenson [OP] Member
    Thousand Oaks, CA
    01 Tacoma LTD 4x4 TRD S/C
    TRD SuperCharger 1st Gen w/ dynamic tensioner, TRD Headers, AEM Brute Force Intake, King Coil Over Front, add a leaf and Billstiens in the Rear
    Hello Everyone,
    I am the owner of a 2001 Toyota Tacoma with a 1st generation supercharger, TRD headers and a AEM Brute force intake. I have recently noticed some degradation in boost pressure over the last few months and was wondering if you all had some insight into some areas to look for problems. Currently the boost gauge is only registering about 4-4.5Lbs of boost when I push it as hard as possible. I was pretty sure when I got it that is was putting out more like 5-6psi when I got the Truck. The car is equipped with the TRD dynamic tensioner and I just replaced all my belts, washed and rinsed all my pulleys, and checked all my lines for vacuum leaks when I noticed the low boost pressure. The TRD installation manual claims that it is supposed to put out 7lbs psi. What kind of boost ratings are you all getting and where else should I look for issues? The PO claimed that they had the whole supercharger warrantied approximately 30,000 miles ago but there was no paperwork to prove it. The truck runs/drives/idles just fine. Any help or suggestions would be great.
  2. Sep 18, 2011 at 2:56 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I don't think Toyota made a 3.6L.
  3. Sep 18, 2011 at 2:57 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Did you put on the headers after you had 5-6lbs or before? Also are you running the proper fuel upgrades for the supercharger?
  4. Sep 18, 2011 at 2:57 PM
    jarondenson
    Thousand Oaks, CA
    You right it is a 3.4L my bad
  5. Sep 18, 2011 at 2:58 PM
    jarondenson
    Thousand Oaks, CA
    The headers were already installed when I purchased the truck.
  6. Sep 18, 2011 at 3:14 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Maybe there is a boost leak in the gauge line
  7. Sep 18, 2011 at 3:20 PM
    jarondenson
    Thousand Oaks, CA
    I checked that as well.
  8. Sep 19, 2011 at 8:04 AM
    jarondenson
    Thousand Oaks, CA
    The truck does not have any fuel upgrades on it and is running the stock size pulley.
  9. Sep 21, 2011 at 9:50 AM
    jarondenson
    Thousand Oaks, CA
    Does anyone know how to check the boost bypass valve to see if it is leaking? I can tell that the mechanical arm changes from one side to the other when the engine is turned on and off. But how do I check and see if it is leaking? I called magnson superchargers. The way I described it to them they seem to think that the vanes are worn out and at this point cannot be replaced because they are no longer produced.
  10. Sep 21, 2011 at 2:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Disconnect the vacuum line going to the bypass valve, with the engine running at idle, see if the idle is smooth, or "lumpy", like its missing. If the idle is smooth, that means the bypass valve is not functioning correctly.
  11. Sep 26, 2011 at 10:17 AM
    jarondenson
    Thousand Oaks, CA
    After further investigation this weekend I have come up with the following. I used a mighty vacc vacuum pump to find out there was a cracked vacuum hose and a line going to the boost gauge was slightly leaking. After fixing those problems I see that my max boost output is around 4.5-5psi. I also can see that the boost bybass is opening and closing when I turn the car on and off. However if I unplug the boost bypass actuator attach it to the mighty vac while running and plug the vacuum port, I see the bypass actuator moving and holding a vacuum with a mighty vac but not really any noticeable difference in idle? Does this mean the flapper/valve inside the supercharger is not working correctly?
  12. Sep 26, 2011 at 10:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Maybe....or not fully closing...
  13. Sep 26, 2011 at 11:04 AM
    jarondenson
    Thousand Oaks, CA
    So the actuator works in this way: at idle the valve should be open to let the boost bleed off and not load up the engine. Then when accelerating the supercharger should be creating boost causing the valve to close and not bleed off the boost, correct? So does anyone know how to properly adjust the end points of the boost bypass valve?
  14. Nov 1, 2011 at 10:35 AM
    jarondenson
    Thousand Oaks, CA
    I wanted to close the loop on this problem as I finally figured out another issue. As basic as it was, the EGR block off plate had lossened off due to the fact that whoever installed it (Supposedly Toyota) used bolts that only went at most a 3/16in into the supercharger body causing it to strip the threads and appear to be locked down, I litteraly unscrewed the bolts with my hand. There was no sealent/gasket installed on the block off plate either and obvious signs of leakage. The only reason I discovered it is becuase I was installing my 7th injector kit. Now boost pressure is around the 5-5.5 Psi mark (7th inj not functional yet), Which is where is was around when I purchased the truck.
