3.73 auto third member swap?
Discussion in '5 Lug' started by 00black5lug, Aug 6, 2017.
  1. Aug 6, 2017 at 7:27 PM
    00black5lug
    00black5lug [OP] DCSSM18
    Dalton
    2018 DC Sr5
    will a 3.73 third member bolt directly into the rear of my 2000 5 lug that has the 5 speed manual? I've heard that the 3.73 third will bolt up but will I need the pinion gear from the donor as well? Asking because my 3.58 with the lift and tires has lost some low end pull and have heard this is a cheaper remedy that will restore some low end torque and bring the speedo back closer to a true mph and will also help to bring back some gas mileage. Thanks!!!
  2. Aug 6, 2017 at 7:28 PM
    00black5lug
    Dalton
    2018 DC Sr5
    Edit: the donor is an automatic first gen 5 lug.
  3. Aug 6, 2017 at 11:00 PM
    SamGoingHam
    SamGoingHam IG: SamGoingHam
    Sam
    Phoenix, Arizona
    2014 TACO 5LUG LOCKED
    You need a matching Ring & Pinion Bro. MPG isn't always going to get better. What tire size did you upsize to?
  4. Aug 7, 2017 at 7:04 AM
    00black5lug
    Dalton
    2018 DC Sr5
    Just went to a 235/75/15 which is 29" but it still took a little power out of it. I pull a trailer from time to time with the truck and would just like to gain some low end back.
  5. Aug 7, 2017 at 11:46 PM
    tacomatt602
    tacomatt602 Well-Known Member
    Phoenix, AZ
    1997 5lug Regular Cab 2.4l
    Doetsch spindles, V6 coils, Fabtech AAL, 4Crawler 2" body lift, Daystar coil spacers, Bilstein 5100s (rear), 15x7 U.S. Wheel Stealth Stars, 225/70r15 Firestone Destination LE2s, '00-04 side mirrors, Prerunner/4x4 grille, Kobalt low-profile toolbox, fucked steering rack D:
    This may or may not be helpful. Still waiting to regear over here too.
  6. Aug 8, 2017 at 10:24 AM
    00black5lug
    Dalton
    2018 DC Sr5
    Thanks man! Hopefully we can find the answers
    tacomatt602 likes this.
  7. Aug 8, 2017 at 5:18 PM
    tacomatt602
    Phoenix, AZ
    We must :curls:
  8. Aug 8, 2017 at 10:08 PM
    00black5lug
    Dalton
    2018 DC Sr5
    I've heard it before that it will work but hopefully we will get confirmation
  9. Aug 8, 2017 at 11:13 PM
    SamGoingHam
    Sam
    Phoenix, Arizona
    Maybe you can chime in and help out a member Ken? @ZUK ?
  10. Aug 8, 2017 at 11:56 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Im not sure about first gens unfortunately.
    HackD likes this.
  11. Aug 12, 2017 at 8:56 AM
    00black5lug
    Dalton
    2018 DC Sr5
    Thanks Sam hopefully we can find the answer
