3.75 offset will it work?
Discussion in '1st Gen. Tacomas (1995-2004)' started by alexlies, Jan 8, 2011.
  1. Jan 8, 2011 at 10:52 AM
    alexlies
    alexlies [OP] Well-Known Member
    Alex
    Battleground
    2002 4 door 4x4
    any one have a set up with 33/12.50/16 or 15 with a 8 wide rim?
    will it rub on the uca and the frame?
  2. Jan 8, 2011 at 1:21 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Do you mean a 3.75" backspacing?
  3. Jan 8, 2011 at 1:50 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    i used to have a set of 33/12.5/15 on a set of wheels with 3.6'' backspace and they would rub on the frame at full lock,they did not rub on the UCA but that is because i have camburg ucas which at shorter they may have rubbed on the ucas if i had stockers.
  4. Jan 8, 2011 at 2:37 PM
    alexlies
    Alex
    Battleground
    2002 4 door 4x4
    yea backspacing i meant sry . ill just go with a different rim with 4.5 backspacing just to be safe i hope
    thanks for your replys
  5. Jan 8, 2011 at 7:40 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    a 4.5'' backspace rim wont help ya none thats the same backspace as stock,thats is if ya want to still go with a 33/12.5
  6. Jan 8, 2011 at 8:10 PM
    alexlies
    Alex
    Battleground
    2002 4 door 4x4
    so what you think will work out? a 285/75?
  7. Jan 8, 2011 at 8:22 PM
    alexlies
    Alex
    Battleground
    2002 4 door 4x4
    what back space would you concider for a 16 and a 15 depending on whitch one i choose im wanting a 33-12.50 or 285/75
  8. Jan 8, 2011 at 9:45 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    If you get 4" bs and a 10" wide rim with 33/12.5 your tire will stick out out about 3-4".
  9. Jan 9, 2011 at 10:19 AM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    you can fit a 285/75/16 on stock wheels with 4.5'' BS no problem,as long as your lifted and dont mind doing a little trimming.
  10. Jan 9, 2011 at 8:06 PM
    alexlies
    Alex
    Battleground
    2002 4 door 4x4
    a 285/75 is pretty much a 33/11.50/16 right? how wide are stock rims?
  11. Jan 10, 2011 at 12:42 AM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    I had 16x8 with 4.5" bs, sold to get 4" bs when I stepped up to 285's cuz that lil bit helps prevent some rub, but not all. A lil trimming helped the rest.
  12. Jan 10, 2011 at 12:44 AM
    DIRT YOTA
    Cory
    Camarillo, CA
    Stock rims are 7" and 285's are 32.8x11.4x16
  13. Jan 10, 2011 at 6:17 PM
    alexlies
    Alex
    Battleground
    2002 4 door 4x4
    so i cant fit a 11.50 on stock rim
  14. Jan 13, 2011 at 4:35 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    yep
