3/8" top spacer with 5100's/884 ?
Discussion in 'Suspension' started by tim3939wil, Apr 8, 2011.
  1. Apr 20, 2011 at 12:59 PM
    #41
    sac130e
    sac130e Well-Known Member
    Scott
    Milton, FL.
    11' TRD Off-Road 2wd
    JVC Nav. System and entire Memphis Audio Speakers/Amps
    Just recieved my 5100's from Suspension Connection and they have the thin black seat also. Still debating on the OME 884's since the Eibach is out of stock everywhere. If I go with the 884, can the 5100 be set at the .85 setting without any issues? Will have the LR UCA's installed also.
    Thx
  2. Apr 20, 2011 at 1:10 PM
    #42
    elgin
    elgin Well-Known Member
    Ian
    Southwest Colorado
    11 DC TRD OR 4x4
    ^^^ If you want the 884's set at .85, i would suggest just getting the 885' there the same as the 884's but longer, so no need to put at .85
    just my .02
  3. Apr 20, 2011 at 1:22 PM
    #43
    sac130e
    Scott
    Milton, FL.
    Want to keep the lift below the 2.5" mark..won't the 885's push it closer to the 3" mark?
    Thx
  4. Apr 20, 2011 at 1:47 PM
    #44
    elgin
    Ian
    Southwest Colorado
    11 DC TRD OR 4x4
    yes but the 884's at .85 will probably give you over three. Just a guess it seems like some get a little over two with the 884's at 0. the 884's at .85 will probably sit higher than the 885's at zero, not 100% sure on that maybe soemone who knows more will chime in.
  5. Apr 20, 2011 at 2:04 PM
    #45
    sac130e
    Scott
    Milton, FL.
    Going with 884's at 0...thx
  6. Apr 20, 2011 at 2:10 PM
    #46
    elgin
    Ian
    Southwest Colorado
    11 DC TRD OR 4x4
    good choice i ordered that setup today!!
  7. Apr 20, 2011 at 2:25 PM
    #47
    sac130e
    Scott
    Milton, FL.
    I am beating my head on the wall about the 884 vs 885 question.
    My main concern for the front is to not have CV issues. I have the TSB done on the back and have the 1.5 AAL sitting here in a box waiting.
    If I went with the 885, I already will be installing the LR UCA's, just beating my head up on whether this would be bad on the CV's.
    Will be riding on MotoMetal 955 w/BFG TA KO 275/70/17 when all is done.
    What to do???
  8. Apr 20, 2011 at 2:43 PM
    #48
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    DON'T SET 5100's AT .85 AND RUN OME COILS! That's bad stuff waiting to happen.
  9. Apr 20, 2011 at 2:45 PM
    #49
    sac130e
    Scott
    Milton, FL.
    I won't...heard good thru here.
    Just debating between the 885 and 884.
    Will the 885 put to much stress on the front joints?
    Worried the 884 won't be enough lift and 885 will be to much...ughh.
    Thx
  10. Apr 23, 2011 at 7:56 PM
    #50
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    needs to be a 884.5 huh?
    maybe its the 884x versions that are giving or maintaining the slightly higher lift.
  11. Apr 24, 2011 at 8:30 AM
    #51
    NC15TRD
    Nick
    PA
    The x denotes that they are the updated springs which don't sag so fast.
  12. Apr 24, 2011 at 1:24 PM
    #52
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    what about eibach 620 coil set at .85? that wil be close to 2.5". Maybe that is some thing you should consider. I am - unless I go ahead and pay for CO's! ---- EDIT --- I just read back and it sounds like Eibach's are not avail now. Well hopefully they will be avaiable in a couple of months.
  13. Apr 27, 2011 at 3:36 PM
    #53
    NC15TRD
    Nick
    PA
    Check the pic in this thread. To me it looks like the 5100 would set the spring higher thus giving more lift?!
    http://www.tacomaworld.com/forum/su...t-kit-vs-toytec-ultimate-coilover-kit-20.html
