3:91 Gears and 33 Inch Tires
Discussion in '1st Gen. Tacomas (1995-2004)' started by Monkeysuncle, Aug 30, 2011.
  1. Aug 30, 2011 at 1:14 PM
    Monkeysuncle
    Monkeysuncle [OP] My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    I am about to bite the bullet and get my suspension up to parr, current set up is stock, but I have been looking at the complete OME set up from Wheelers, with the 881 and 1.5 inch lift. I have used the tire size calculator and see the 3.91 gears are good with the ratio I have with 31X15 inch tires, but if I go to 33's what can I really expect out of my gears with a 5 speed. I am on here all the time but and hate to post this but I am really confused on the final driveability of my truck, from what I see I might loose some highway MPG??? What happens if I go to a 16 inch wheel, like the steel rim from wheelers? Sidewall will be more stout, so can I get a smaller tire (like a 31X10.5X16) and help me out in the long run? Any help would be great. Thanks Kevin
  2. Aug 30, 2011 at 1:16 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    first gens have 4:10 gears stock to turn a bigger tire you need a lower gear ratio depending on how big you go
  3. Aug 30, 2011 at 1:20 PM
    Monkeysuncle
    Kevin
    Florida
    Mine is for sure a 3:91 checcked and re checked the sticker on the drivers door. That's why I am scratching my head. NON TRD just a 1999 4x4 extra cab SR5, in need of some springs,shocks and tires
  4. Aug 30, 2011 at 1:22 PM
    2000GTacoma
    Snow Hill NC
    i checked mine and its 4:10 gearing and mine is a 2000 non trd just 4x4
  5. Aug 30, 2011 at 1:22 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    you stick with the same gears and larger tires *in theory* you should get better freeway gas mileage because your RPM's are lower. your around town gas mileage will suffer as you will need to get into the gas pedal more to get moving. All depends on what you want the truck to do and what your end result plans are ie, wheeling, freeway driving, larger tires in the long run...what are your plans?
    I am 10% over-geared and LOVE the drive-ability of the truck now. More low end power, yes the RPM's are a bit higher on the freeway but the engines not working as hard and I still get 24 mpg.
    you move up from 15 to 16, heavier wheel (especially going to steel) and more expensive tires are what your going to get. tires arent available like you described 31x10.5x16, it would be something along the lines of 245/75/16. stick with the 15's, wish i could run them easily!
  6. Aug 30, 2011 at 1:24 PM
    Monkeysuncle
    Kevin
    Florida
    thanks, I haven't actually looked for the 16 inch tires yet
  7. Aug 30, 2011 at 1:24 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i think if hes a 6 cyl he has 3.91s, 4 cylinders have 4.10s
    and what oliver said! stay with 15s:)
  8. Aug 30, 2011 at 1:32 PM
    2000GTacoma
    Snow Hill NC
    i have a v6
  9. Aug 30, 2011 at 1:33 PM
    08pretaco
    Oliver
    az
    i got my 4.56 from a 2000 4 cylinder :)
  10. Aug 30, 2011 at 1:35 PM
    97yota4wd
    Eric
    Mesa, AZ
    weird....... and oliver that means it was after market:)
  11. Aug 30, 2011 at 1:36 PM
    08pretaco
    Oliver
    az
    nope :D some 4 bangers came 4.56 from the factory! weird i know
  12. Aug 30, 2011 at 1:37 PM
    97yota4wd
    Eric
    Mesa, AZ
    have proof of this????
    im 99.8 percent positive thats not true lol. unless it was traded in with the 4.56s
  13. Aug 30, 2011 at 1:38 PM
    08pretaco
    Oliver
    az
    ill find the proof again, give me a bit..im in class
  14. Aug 30, 2011 at 1:42 PM
    97yota4wd
    Eric
    Mesa, AZ
  15. Aug 30, 2011 at 1:47 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I hated driving my truck with 33's and the stock 4.10's, and I have a supercharger. Quite honestly regearing to 4.56 was one of the best mods I've done to my truck (and I've done a lot).
  16. Aug 30, 2011 at 1:50 PM
    08pretaco
    Oliver
    az
    http://forum.ih8mud.com/95-gen-toyota-trucks/199061-tacoma-gearing-question.html
    obviously i do not have the guys vin number
    http://www.tacomaterritory.com/forum/showthread.php?p=2182499
    "Most Toys sold in the US have 4.10 axle gearing, but this isn't always the case. Four cylinder models with auto trannies often have 4.30 gearing, (4.87 if they came factory-equipped with 31" tires). All V6's with 31" tires and 4-cylinder manuals with 31" tires usually had 4.56 gears. And still others have been changed by their owners, to move oversized tires."
    From: http://www.off-road.com/trucks-4x4/tech/toyota-differential-identification-18588.html
    "Any U.S. sold that came with 4.56 or 4.88 gears came stock with 31x10.5-15 tires or
    265/70R-16 tires."
    From: http://www.brian894x4.com/Gearratiosanddiffs.html
    " In 1995, Tacomas with 31s got the following gears, 4.10 for V-6 and 4 cylinder manual transmissions and for V-6 automatics. 4 cylinder automatics got 4.56 gears."
    From: http://www.brian894x4.com/Toyotapickup4Runnermodels.html
    Need any more proof? I am tired of looking
  17. Aug 30, 2011 at 1:52 PM
    97yota4wd
    Eric
    Mesa, AZ
    lol i agreed i was wrong 10 min ago:D
  18. Aug 30, 2011 at 1:53 PM
    08pretaco
    Oliver
    az
    ya sorry just noticed that, too busy researching lol :)
    Suprised the hell out of me also!
  19. Aug 30, 2011 at 1:54 PM
    97yota4wd
    Eric
    Mesa, AZ
    i wish my truck came with 4.56s stock...:(
  20. Oct 3, 2013 at 2:01 PM
    motostar00
    motostar00 Grind it till ya find it
    N.C
    tinted windows, 3 inch bilstein/eibach lift , LED head lights, 35 super swamper TSL SX2's and Raceline bead locks, air bagged rear, 1 10 inch Kicker Comp R
    Some 2000 model tacomas had 3.90s in them. Mine did but I regeared to 4.56 and it makes a huge difference
