3" All Pro AAL or 2.75" OME... which one is "better"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DrRabbitFurHead, Jul 26, 2009.
  1. Jul 26, 2009 at 11:46 AM
    DrRabbitFurHead
    DrRabbitFurHead [OP] Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    I've been doing a bit of research and am trying to get someone who's done their homework to chime in. All Pro offers a "rear kit" with longer brake lines, but they are "not designed for weight carrying capability".
    The OME kit doesn't come with longer brake lines, but it comes w/ a diffy spacer.
    I'm trying to figure out why 0.25" on one requires longer brake lines and not the other. Also, how do you find out the "weight carrying capabilities" of each of the spring packs?
    I'll end up doing as much off roading as I will hauling so that may factor in...
  2. Jul 26, 2009 at 12:24 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    The All pro packs are specifically designed to be flexy for offroading. The Dakar packs are supposed to be flexy, but retain the load capacity better- Less flexy but that means they hold weight better. I don't know that there is a place that says Xlbs tho...
    Really any rear lift should have extended brake lines if you going to be off roading/flexing the rear end. You can do without- but it's a good idea.
