3 arm puller to remove hub assembly from knuckle
Discussion in 'Suspension' started by lipripr, Jul 6, 2024.
  1. Jul 6, 2024 at 3:06 PM
    lipripr
    lipripr [OP] Active Member
    Colorado
    2006 TRD 4x4
    if using a 3 arm puller to remove the old assembly is it ok to push against the end of the axel with the stem of the puller? Or is that too much inward force against the cv joint? Thanks for any advice.
  2. Jul 6, 2024 at 3:18 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    No don't use the CV shaft as a forcing point.
    The hub shouldn't be all that tight in the knuckle but if it is then either hit it with a hammer or use a slide hammer with a hub puller attachment.
