3" body lift suggestions? install tips?
Discussion in 'Suspension' started by tacomakyle, Dec 12, 2011.
  1. Dec 12, 2011 at 6:07 PM
    tacomakyle
    tacomakyle [OP] Member
    kyle
    Manitoba Canada
    03 2.7l SR5
    3" suspension lift
    looking to buy a 3" inch body lift and I want to buy one that has a good track record any reccomendations and def. going to install myself , any tips?
  2. Dec 12, 2011 at 6:08 PM
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
  3. Dec 12, 2011 at 6:08 PM
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
  4. Dec 12, 2011 at 6:48 PM
    Tacoma9396jrc
    Tacoma9396jrc Well-Known Member
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    Cherry Bomb exhaust, 3" suspension lift
    I would not go with a body lift, especially 3", that is too much for a BL. You're gonna sway, your gonna be top heavy, and see a lot of your rails. I would go with a suspension, they'll run you around the same price depending on what you get
  5. Dec 12, 2011 at 7:46 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Here's a tip, don't get a body lift :thumbsup:
  6. Dec 12, 2011 at 7:50 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x10000000000000000000000000000000000000000000000000000000 ;)
  7. Dec 12, 2011 at 7:56 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    as an owner of a truck, whom is repairing the damages of the previous owners body lift, i can honestly say, dont do it.
    for a few reasons. PITA to properly extend all the lines, e-brake,fuel, break, shift linkages, and steering. The cost of propery doing it, you might as well of just done it right the first time.
    If you dont do it right, your breaks can act up, your ebrake wont work, your fuel will spill, and thats like liquid gold right now, and your shif linkages could break like mine did.
    On top of that i dont think theres much uglier then seeing the frame of a truck, its meant to be tucked up and under.
    I suppose the ONLY plus side is if you want your truck to look larger, and to other bros it will. but to anyone who enjoys vehicles, even as a hobby, the body lift is an unpleasant eyesore.
  8. Dec 14, 2011 at 8:11 PM
    tacomakyle
    kyle
    Manitoba Canada
    03 2.7l SR5
    3" suspension lift
    i have a 3" tuff country lift kit allready on do any of you know if I can also add the 2" leveling kit? or is there not enough room to compress the strutts that much?
  9. Dec 14, 2011 at 8:20 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    No.
    /endthread
  10. Dec 14, 2011 at 8:24 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    lol this is crazy. i have to agree with the rest of the guy's that a 3inch body lift would look completely awful.
    some guy's who already have a 3inch suspension lift run a 1inch body lift to clear some real big tires 35's and 36's but, imo if you want to go higher and fit a bigger tire drop bracket is going to be a better all around solution for you that and alot of trimming.
    although i can see how you could think otherwise a nice drop bracket lift will run you more than a couple thousand where as a body lift is like 100 dollars lol. anything over 1inch and your going to need to do alot of extra work and that means money a lot of money most likely.
