3" Coilover Setup?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco11, Oct 10, 2010.
  1. Oct 10, 2010 at 1:49 AM
    Taco11
    Taco11 [OP] Well-Known Member
    Seattle WA
    So I want to lift my 2011 Taco TRD Off-Road but I dont want anything crazy. I was thinking a 3" coilover setup. I tried searching but I got too confused with all the different variables...
    What would you all recommend?
  2. Oct 10, 2010 at 9:05 AM
    N3ZAT
    N3ZAT Well-Known Member
    Charlie
    Coatesville,Pa.
    09 tacoma
    saws up front/TC UCA/rear AAL
    265 bfgs ,camburg or saws 2.5, diff. drop ,swaybar extender,add a leaf rear use same shocks.
  3. Oct 10, 2010 at 9:16 AM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    I have an ome setup and its way to hard for me. I wish I would've bought camburg or icon coilovers.
  4. Oct 10, 2010 at 9:19 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    OME Lift w/885 coils (886 if you plan on getting a bumper) aal, light raceing UCAs or if you plan on going wheeling at all something with a uniball the'll perform better. you can get the lift from www.toyteclifts.com
  5. Oct 10, 2010 at 9:27 AM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    Toytec ultimate lift kit w/ carrier spacer, tc uca's, ome/dakar rear leaf pack.
  6. Oct 10, 2010 at 10:53 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Compare the spring rates and damping. I'm guessing you'd find the same ride issue on either of those coilovers. Only difference is since they're adjustable on the truck you could dial down the ride height a little lower.
  7. Oct 10, 2010 at 10:55 AM
    Taco11
    Seattle WA
    So its between OME, Toytec, and Camburg for you guys. What about Fabtech? are they any good?
  8. Oct 10, 2010 at 10:56 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    ICON's and Camburgs/ SAW are different as well, digressive vs progressive.
    I love my ICON's, but everyone is going to tell you what they think is the best and you won't get an accurate comparison.
  9. Oct 10, 2010 at 10:58 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    To the OP:
    Depends on what you want to use it for, and how much tolerance you have for "follow up" tinkering - vibration diagnosis, VSC issues, trimming to fit larger tires, UCAs to correct alignment, front axle CV and diff bearing issues, etc...
    You say you "don't want anything crazy." The most bulletproof option, least likely to cause issues is:
    bilstein 5100s all around, set at 1.75" in front with 1.5" add-a-leaf in back and 265/75R16 tires (which at 32" diameter are about 1" taller than your stock 265/70R16s) You might have to remove your front mudflaps.
  10. Oct 10, 2010 at 11:00 AM
    Taco11
    Seattle WA
    I suppose I should ask do I really need coilovers.. Or would say some Bilstein 5100's be ok?
  11. Oct 10, 2010 at 11:02 AM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    the 5100s are good for everday use and occasional off-road use. Doesnt require new coils and relatively fair priced
  12. Oct 10, 2010 at 11:08 AM
    Taco11
    Seattle WA
    This truck will be about 98% on road.. at least for now. So maybe this is the way to go. Tinkering doesn't bother me too much. Its what I do for a living so no big deal.
