3" coils w/ 2" AAL
Discussion in 'Suspension' started by Campbell2010, Dec 1, 2009.
  1. Dec 1, 2009 at 5:17 AM
    Campbell2010
    Campbell2010 [OP] Member
    Trip
    Florida
    2010 2wd Tacoma
    Was just looking on toytec at 3"coils and 2" aal. looks likea good deal.. You think i should go for it?
  2. Dec 1, 2009 at 5:45 AM
    misterquad
    misterquad Well-Known Member
    Since you have a new truck I will give you this heads up about AALs; they sqeak after a couple of weeks or so. Especially after you get a little dirt in them. It really annoyed me. I talked to several people and it is a normal issue. You need to grease them when you install them and on a regular basis afterwards.
    The other thing to look at is the coilover rubbing the sway bar even with the relocation brackets installed. This is an issue with other brands of coilovers beside Toytec. I just read someone having the same issue with their Camburgs. It happens and annoyed me.
    I would suggest looking at OME too. If I could do it over I would have bought OME with Dakar leaf springs.
  3. Dec 1, 2009 at 8:36 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    First off, our AAL don't squeak. Not a common complaint, or people don't comment on it.
    We use anti-friction pads on our AAL to prevent just that.
    Greasing the AAL :confused:
    The kit you spoke of should work excellent for you. You just need to pick which coil is best going to fit your load capacity needs.
  4. Dec 1, 2009 at 8:38 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    my 1.5" aal from you guys sqeak after 14k miles i dont really care, i spray some wd40 or pressure wash them then the sqeak goes away for a few weeks
  5. Dec 1, 2009 at 8:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2. If the springs squeak, its due to a poor cleaning during install, or a soak in the mud. My AAL's havent squeaked ever....
  6. Dec 1, 2009 at 8:47 AM
    misterquad
    Mine squeak. I was advised to use white lithium grease by the dealer that sells your products. Their whole office staff knew squeaking is a very common problem that they also suffer from squeaking AAL.
    And yes, a WD-40 soaking, helps me get through for a couple of weeks.
