3" exhaust
Discussion in 'Performance and Tuning' started by grizzbear, Oct 11, 2012.
  1. Oct 11, 2012 at 7:45 PM
    grizzbear
    grizzbear [OP] Well-Known Member
    got a sweet deal on a 3" exhaust cat back system what are the pros and cons of a 3" system on our trucks/
  2. Oct 11, 2012 at 7:53 PM
    grizzbear
    what about back pressure?
  3. Oct 11, 2012 at 7:55 PM
    grizzbear
    so just a little loss in low end power
  4. Oct 12, 2012 at 10:50 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Big exhaust will cause loss of SCAVENGING not backpressure as most people are led to believe.
    You will lose some low end power, you might pick up a tiny bit on top. Not really good on a daily driver unless you rev the shit out of it.
  5. Oct 12, 2012 at 10:53 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I have the urd 3 in catback and its not that much loss in low end.
  6. Jan 2, 2013 at 3:20 PM
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    which cat back did you buy? how does it sound and any drone? what was the special price and from who?
  7. Jan 2, 2013 at 4:09 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    There is a point where a larger size hurts instead of helps. Hot air flows faster, and with a larger pipe, it won't stay hot down the legnth of exhaust. Cooler exhaust=less scavenging(vaccum pulled on one cylinder, caused by previous exhaust pulse)
    Our engines are tuned for a stock exhaust and intake.
