3 full inch lift kits?!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sam_4x4OffRoad, Oct 4, 2022.
  1. Oct 5, 2022 at 6:09 AM
    SenorTito
    SenorTito Well-Known Member
    Denver
    2016 TRD Sport DCSB MT | 1992 80 Series Land Cruiser
    RRW RR7-H, 285/70/17 General Grabber ATX, King 2.5s, Prinsu Roof Rack
    It's a bit too stiff for me, I didn't think I was going to take my truck off-road too much when I was picking suspension (I ended up going out almost every weekend), and I thought the RC kit would be good enough but It felt a bit cheap when I put it on. I feel like the off-road performance is a bit limited when It comes to high-speed stuff as well as soaking up bumps in the road, it feels planted on the road because it's so stiff but Its speed doesn't soften up bumps like I was hoping.
    When I bought the kit I had 3.5" of lift and now that the suspension has settled down to around 3.1" (Which is fine because 3.5" was a bit too tall for my liking). I'm sure there are people who are fully satisfied with that kit but it's just not for me.
    Are you looking at buying an RC kit?
    nglescobar1992 and Road_Warrior like this.
  2. Oct 5, 2022 at 7:15 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You can run 255/80/17 or 255/85/16 which are 33x10 on stock suspension.
    Regarding a lift, I wouldn’t do more than 2”. I’ve got an OME nitro charger shocks, 2887 coils, and dobinsons leafs. Truck drives great!
  3. Oct 5, 2022 at 7:22 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Plenty of threads that answer your questions to include an entire section of the forum dedicated to suspension. Check it out.
    Mully and 9th like this.
  4. Oct 5, 2022 at 8:36 AM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    Coming from a 2012 with Fox's and putting in the RC 3.5 Lift I can tell you it is stiffer than the Fox's.
    Which is better for me cause I prefer stiffer on the road compared to the mushy stock Bilsteins. I also
    pull a boat so I need the stiffer ride. Fox's were soft as butter. Too soft for some. I think the RC lift is
    fine off roading at the right speeds. I don't think there is a perfect suspension lift. For the $1200 I spent
    on the Rough Country if I am unhappy down the road I can switch. But right now I don't see that happening. :burnrubber:
  5. Oct 5, 2022 at 8:54 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    In dark mode, that text colour is difficult to read!!!
  6. Oct 5, 2022 at 12:34 PM
    Sam_4x4OffRoad
    Sam_4x4OffRoad [OP] Member
    Calvary Blue 2019 TRD Off Road Manual Transmission
    I think I’m going to do that but with an AAL in the rear! Thanks!!
  7. Oct 5, 2022 at 12:34 PM
    Sam_4x4OffRoad
    Yeah spending anywhere from 1500-2250 is kinda where my budget is at, so I’ll definitely look into those lifts!! Thanks man
    SenorTito[QUOTED] likes this.
  8. Oct 5, 2022 at 12:51 PM
    RebleAZ
    RebleAZ Well-Known Member
    Troy
    AZ
    2020 Cement TRD Off Road
    Fox Performance Elite, RRW -25 RR7H, 295/70/17 Yokohama Geo MT. Alcan Leafs. Much more...
    I fully agree wit this. My coil overs were adjusted when I changed my springs and its sitting at 3” and th bump steer is ridiculous. Rides like shit and rode much better at 2.5” lift in front. I cannot adjust the coil over myself and can’t wait to get it back to the right height.
    SenorTito likes this.
  9. Oct 5, 2022 at 1:45 PM
    SenorTito
    Denver
    Second on that agreement, 3" looks cool but it's a rough ride for sure.
    The guy I'm planning to buy my new set up from said that almost all suspension performance is lost when you lift over 2.5". My 3" lift still doesn't clear my 285's but that's because my wheel has a -12 offset, hopefully, some SPC's and light massaging can stop the rubbing.
    Just account for all the small things when you eventually pick your setup.
  10. Oct 5, 2022 at 2:20 PM
    BottleShark
    BottleShark Well-Known Member
    TJ
    Bullard, Tx
    2018 White TRD Offroad Long Bed
    2" lift, AAL Rear, Front bumper, 12k Winch
    You think it would be ok if I have a front winch?
  11. Oct 5, 2022 at 3:21 PM
    SenorTito
    Denver
    Doubtful, I’m not sure if I’d recommend it since I’m not sure what the spring rate is but I’d recommend one of the lifts I mentioned earlier.
    What budget do you have for a lift?
  12. Oct 5, 2022 at 3:50 PM
    BottleShark
    TJ
    Bullard, Tx
    I don't really have one yet. I'm thinking about the 5100 with heavy duty springs, as I'm adding a winch mount and winch. Do the 5100's get the lift just from preloading the springs? Or are they a longer shock body?
  13. Oct 5, 2022 at 4:04 PM
    SenorTito
    Denver
    I’m not confident but I thought the struts were longer but it might be a mix of both?
    I’d got that route rather than an RC kit, I’d definitely layout a budget first though.
  14. Oct 5, 2022 at 4:30 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    The Bilstein 5100 shock absorbers have a finite preload adjustment and that is how ride height is modified.
  15. Oct 5, 2022 at 6:06 PM
    #35
    BottleShark
    TJ
    Bullard, Tx
    So they are the same length of Stock OR struts? If so, could I just add the heavy spring to the stock Struts?
  16. Oct 6, 2022 at 4:25 AM
    #36
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    I believe the fact that you can raise/lower the spring perch is what gives the lift.
  17. Oct 6, 2022 at 4:38 AM
    #37
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    I can read the text with no problem but the bouncy tits are more annoying than the text. just saying
  18. Oct 6, 2022 at 4:56 AM
    #38
    BottleShark
    TJ
    Bullard, Tx
    So it’s just preloading the spring.
  19. Oct 6, 2022 at 5:14 AM
    #39
    atc250r
    Orange County, NY
    They might also be longer below the perch to provide lift but you can definitely preload the spring with them.
  20. Oct 6, 2022 at 5:25 AM
    #40
    Clearwater Bill
    Billy
    Largo Florida
    You don't need a lift to run 33". You just need the correct tire/wheel combo.
