3 inch body lift?
Discussion in '4 Cylinder' started by flyers9780, Sep 1, 2011.
  1. Sep 1, 2011 at 4:58 PM
    flyers9780
    flyers9780 [OP] Member
    i have a 2001 toy tac 4 cyl 2.7 lit.... thinking about putting a 3 inch body lift with 33 inch tires. question is how much do you think it will cost with lift and a garage installing it? also would i have to change the gears or anything? or how much would a 3 inch suspension lift go for?
  2. Sep 1, 2011 at 5:05 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Don't get a body lift. Period.
    its the cheapest lift but makes your truck less safe, and adds nothing to offload ability
    Also, I don't think 33s are a good idea on a 4banger. It'd be like an elephant riding a moped.
    The cheapest cusp lift would be to go with 5100s (less tthan$300 form downsouth motorsports) set at 2.5 on the front with an AAL in the back (70 from toytec lifts)
  3. Sep 1, 2011 at 5:17 PM
    flyers9780
    ok thanks. what are 5100's? is that a susp lift? and how much would it be to change gears
  4. Sep 1, 2011 at 5:26 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    There's so much info on the site, just take a look around and do some research, might find other options you like :cookiemonster:
  5. Sep 13, 2011 at 5:36 PM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    putting a body lift is the worst thing that you can do, esp to 4 banger, i put one on mine and now its cracking through my frame in the back and the front.
    i had to get the front one welded back in place with a custom plate because it literally cracked all the way through my frame after hitting a ditch.
    dont get me wrong it looks good with 33's, but its not worth it, just get the suspension kit. another down fall is if u dont buy the space guards to cover the gap in the back it looks retarded and they aint cheap otherwise youll be able to see straight through the bed of your truck and the frame
  6. Sep 20, 2011 at 9:53 AM
    tekki9
    tekki9 New Member
    Owner
    new jersey
    Built to Beat
    3" suspension, leaf rear, coil over fronts - supercharged v6 (pushing 6lbs) - Rhino lined undercoating & bed
    Hey Brother,
    I have ran a 3" body & a 4" sus. lift with a 4cly & a race cam - -
    all good - - using a wide block or better yet - believe or not hockey pucks. will
    provide a larger footprint at the mounting points and wouldn't cracked the body.
    Oh yeah by the way I run 39.5 tsl swmprs - yes on a 4cyl. 5sp man. trns & cntrfrce clutch - - -
    I beat the crap out of it, I jump the bitch - - i built it to KILL IT!
    You can weld or even place a metal plate on top of the lift to widen contact to the body - - -
    jmtc -
  7. Sep 20, 2011 at 9:58 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    X2 you run 39's :confused: :worthless:
  8. Sep 20, 2011 at 12:25 PM
    99TacoDriver
    South Louisiana
    yea thats what i did to the front one, i welded a plate to stop the cracking but i havnt got to the back one yet
  9. Sep 20, 2011 at 12:35 PM
    yota new.o
    yota new.o Well-Known Member
    joe
    klamath falls oregon
    96 tacoma 2.7 sr5
    fabtech dirtlogic coilovers with all-pro a-arms chevy 63" leaf springs billi 5125 12" extended bore shockins in rear headache rack duplicolor bed armor bumpers kc daylighters front fenders corbeau racing seats custom bed rack
    could you take those 5100's and use them with a spacer as well to achieve more lift. your upgrading the shock performance and gaining height with both
  10. Sep 20, 2011 at 12:39 PM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    ahh touche i didnt think about that cause i have a spacer on right now and block in the back bad idea. the leafsprings are shot in the back but the front is holding up just fine. a set of wheelers f pack leafs and 1.5 toyotec shackles for the rear but for the front could i leave it just with the spacer. id does see dirt and mudd but not very often?
  11. Sep 20, 2011 at 12:56 PM
    Triangleacre1
    Triangleacre1 Well-Known Member
    Dustin
    Delaware
    01 Tacoma SR5
    Check out www.fatbobsgarage.com I got my lift there. Its a spacer in the front and AAL in the rear. I know many people don't like the spacers tho.
  12. Oct 3, 2011 at 11:25 PM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    body lifts are garbage....my taco had one from the previous owner and i feel like im gonna roll the bitch on every turn.
    you can have mine if you come take it off my truck.......lol
    im taking it of anyway, fuck body lifts!
    her-derp
  13. Oct 4, 2011 at 1:39 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    bad bad bad idea
  14. Oct 4, 2011 at 2:04 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    I agree that suspension lifts are better than body lifts, but not for this reason^^^.
    Why would a body lift make it feel like you are going to roll your truck? A suspension lift raise your whole body and frame with engine, transmission etc. vs. a body lift that raises only the body, so with a suspension lift your center of gravity is actually higher than with a body lift, so it would feel even more like it's going to roll with a suspension lift.
    (A statement like this should be clarified that there is a difference between suspension lift with spacers and original suspension components vs. suspension lift with super dooper stronger suspension components.)
  15. Oct 4, 2011 at 4:04 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    perhaps its because with a quality suspension lift you get more "sturdy" suspension that reduces body roll, when a body lift just props the body up by X'' and the stock (most of the time) suspension is retained.
  16. Oct 6, 2011 at 2:51 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    I say that it makes it feel like it's gonna roll. It feels that way to me because your elevated above the rest of the vehicle on a pedastool so there is more moment in the sway of the truck from up there. Not saying it would roll. But I wouldn't take my chances with the way it feels...
